Tranny issue?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42320
Printed Date: November-15-2024 at 9:25pm
Topic: Tranny issue?
Posted By: Jaxboater
Subject: Tranny issue?
Date Posted: January-19-2018 at 3:51pm
Hey guys, I am working on my boat and had my engine compression tested "did great"- rebuilt carb, did plugs, wires etc.   "1979 correct craft 351",      when I had it started it sounded great, then I put it in gear while sitting there in yard and the tranny whined pretty dang loud.
what could that be? was thinking where prop pole goes out the back of boat?
JaxNole
1979 Tique
Date Posted: January-19-2018 at 4:27pm
Did you wet/soap down the cutlass bearing for lubrication?
Date Posted: January-19-2018 at 4:31pm
Don't know much about boats to know what you are talking about.....    boat was willed to me after I took care of person who had cancer.
can you describe it a bit for me so I can try tonight?
JaxNole
1979 Tique
Date Posted: January-19-2018 at 4:35pm
The cutlass bearing is the rubber bushing inside the strut. It's water lubricated and if dry and the prop shaft is rotating it will squeal. The strut is the prop shaft support just forward of the prop. If you want to put the boat in gear on land, you need to wet/soap the cutlass for lubrication.
Date Posted: January-19-2018 at 4:39pm
im thinking the boat guy who did my compression test ran it dry since I never had a whine noise before.
so that's all I have to do it lube that ?
JaxNole
1979 Tique
Date Posted: January-19-2018 at 4:43pm
Harry,
Is your "boat guy" familiar with inboards? Sounds like he's an I/O guy!
Yes on the soapy water. Just wet down the shaft forward of the strut and the mix will run into the cutlass.
Date Posted: January-19-2018 at 4:46pm
Yeah they do boat types of boats. when I was going through it and listening to what he had to say , he mentioned that noise and had some type of rubber looking tube and advised I use that to stop the noise..... it looked like window caulking /tube for a house.
wont be going there again.
JaxNole
1979 Tique
Date Posted: January-19-2018 at 4:49pm
he mentioned that noise and had some type of rubber looking tube and advised I use that to stop the noise..... it looked like window caulking /tube for a house. .
Harry,
I think somethings been lost in the translation! If you see him again, ask him to explain it to you again.
How about some pictures of the boat?
Date Posted: January-19-2018 at 4:52pm
well I posted the ones where I redid carb, tune up , ripped up carpet to start rear stringer replacement.
JaxNole
1979 Tique
Date Posted: January-19-2018 at 4:56pm
I know I need to take more, but I work so much my projects take longer to do.
JaxNole
1979 Tique
Posted By: Duane in Indy
Date Posted: January-19-2018 at 5:06pm
Here is a shot of a strut. Obviously the boat is upside down but you should get the picture. Prop shaft is also missing.    I use liquid dish soap to lube the shaft where it meets up with the strut. Soak it down pretty good.   Limit you in gear time to a minimum and keep the RPM's down also.   Squeal is normal with a dry bearing.
        1978 Mustang (modified)
Date Posted: January-19-2018 at 5:19pm
AWESOME MAN.      as soon as I get the last 2 stringers done will take a pic, then goes in the floor, carpet and new seats/bubble.   will be done.
only took me a year    lol
JaxNole
1979 Tique
Date Posted: January-19-2018 at 5:21pm
Especially when you get to the stringers. I'm concerned that you mention the rear replacement as in you are only going to replace the aft ends of the stringers?
Date Posted: January-19-2018 at 5:33pm
It looks to me like the ones on the sides are the bad ones. truthfully I don't even know if I could do that type of work.
day job is a compliance analyst and off time I build/ work on cars and motorcycles.
have read a few articles here...don't know how to get a stringer to fit much less the floor "pretty sure it has to be cut at an angle" or something.
JaxNole
1979 Tique
Posted By: phatsat67
Date Posted: January-20-2018 at 9:34am
So you’re just replacing the rear secondary stringers that make up the floor structure?
Sounds like with a little help you could be a better boat mechanic than your “boat mechanic”. Welcome.
