help
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4265
Printed Date: June-26-2024 at 11:14am
Topic: help
Posted By: kevel
Subject: help
Date Posted: July-24-2006 at 2:19pm
i have a 1995 super sport nautique and yesterday the rear sundeck which covers the engine stopped working. i hit the switch and i get nothing. anybody out there have this problem before?? also, anyway to open this cover manually.....thanks....fred buckman
------------- fred buckman
Posted By: Hollywood
Date Posted: July-24-2006 at 3:17pm
Copied from some "other" site...
Take out the rear seat bottom and reach through the side to access the battery. There is a divider between the rear compartment and the backseat but you can push it out of the way to access the battery.
Posted By: kevel
Date Posted: July-25-2006 at 2:09pm
thanks hollywood, accessed the battery and found a blown fuse..works fine now. thanks for your help
Posted By: nates78ski
Date Posted: July-25-2006 at 3:02pm
wow! those supersport's rear sundecks wont open manually? learn something new every day!
------------- Nathan http://correctcraftfan.com/diaries/details.asp?ID=1463&sort=&pagenum=3&yrstart=1978&yrend=1978" rel="nofollow - My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Posted By: kevel
Date Posted: July-25-2006 at 3:10pm
hi nate, they will open manually if you remove the back access panels and crawl back under the deck cover and remove the hinge pin.
it is quite a project to remove the pin due to the cylinder being under pressure from the hydralics. i had to hammer it out. i should have checked the fuse first. dah!
