Maintainance
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42878
Printed Date: October-06-2024 at 4:29pm
Topic: Maintainance
Posted By: mjgha
Subject: Maintainance
Date Posted: June-03-2018 at 9:46am
Hey guys,
To elaborate on my question from yesterday, I have a two piece rear main seal which i have to replace... meaning i have to remove the oil pan.
Im wondering if there any other things i should replace while i have the oil pan removed?
The engine has done around 1200 hours, and still runs perfectly. Its a SN CC GT40 5.8 95.
Ethan
Posted By: Duane in Indy
Date Posted: June-03-2018 at 9:55am
Welcome to the group. If everything seems OK then I would just install the new seals. Oil pumps are cheap, but seldom wear out. Short of main and rod bearings, then there is not much that you could do. You will probably need to consider a complete rebuild at some time in the future, but if it runs good now then just reseal it and go play.
Posted By: gun-driver
Date Posted: June-03-2018 at 10:24am
If it’s a ‘95 GT-40 you DO NOT have to remove the oil pan, it a one piece Been there done that
Posted By: Gary S
Date Posted: June-03-2018 at 10:26am
Ford oil pans tend to rust through. While it's off go over it carefully,clean and paint if needed. They are getting hard to find here in the states- impossible where your at.
Posted By: Gary S
Date Posted: June-03-2018 at 10:27am
Paul in another thread he has shown pictures,the block has been replaced with an earlier 2 piece one.
Date Posted: June-03-2018 at 10:33am
Posted By: baitkiller
Date Posted: June-03-2018 at 11:17am
Gary S wrote:
Ford oil pans tend to rust through. While it's off go over it carefully,clean and paint if needed. They are getting hard to find here in the states- impossible where your at. |
I have an entire can of spray on truck bed liner on my oil pan. I think it was 8 coats LOL.. But its a $280 pan and I run in sea water.
------------- Jesus was a bare-footer.............
