Tranny seal
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=43005
Printed Date: November-15-2024 at 6:41pm
Topic: Tranny seal
Posted By: connorssons
Subject: Tranny seal
Date Posted: June-21-2018 at 6:52pm
Does anybody off hand know the input shaft seal replacement number on a 72c Velvet Drive
Posted By: KENO
Date Posted: June-21-2018 at 10:35pm
connorssons wrote:
Does anybody off hand know the input shaft seal replacement number on a 72c Velvet Drive |
It's the same as a 71C seal
PCM part number is R047003
National 470774
Alto 023420
and a bunch of others will cross reference
1.375 ID 2.0662 OD .375 width
Date Posted: June-22-2018 at 3:38pm
Thank you so much for the information especially on the other name brands getting ready to put the big block in my Barefoot and wanted to replace the seal!
Date Posted: June-22-2018 at 4:16pm
Jeff, Take a close look at the shaft. If it looks bad, you may want to put a speedy sleeve on it.
Date Posted: June-23-2018 at 8:05am
if its needed pete, where do you get one of those?
Date Posted: June-23-2018 at 8:17am
Jeff, An auto parts store Was there a leak when it was running before?
Posted By: Duane in Indy
Date Posted: June-23-2018 at 10:34am
Speedy Sleeves are a great fix for worn shafts, but bear in mind that you will have to cut it off the shaft to remove anymore than the front cover. Just make sure that you don't have to dig any farther than the front cover before you install it.
Date Posted: June-23-2018 at 10:50am
Jeff, Duane is correct that if you need to get into the trans say for rebuilding, the sleeve does need to be cut off but, I don't feel that would be a major obstacle over a rebuild. The removal is due to the shoulder on the sleeve.
Date Posted: June-24-2018 at 9:15am
it was not leaking, just wanted to stick one in before motor was replaced. hello again Duane, and thank youPete
