Zerc, zerk fitting for 25hp Yamaha?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=43015
Printed Date: March-01-2025 at 5:14am
Topic: Zerc, zerk fitting for 25hp Yamaha?
Posted By: Dziadzi
Subject: Zerc, zerk fitting for 25hp Yamaha?
Date Posted: June-23-2018 at 1:13pm
While using my new grease gun to infuse grease into my F25 Yamaha outboard, I somehow broke off the zerc (zerk) fitting that is attached to the tiller. i bought an "Ezee out" to remove the broken off fitting, however, I don't know if the replacement should be an SAE "1/4"--28" fitting or a "metric 6mm" fitting. Sure, I can buy one on ebay for almost $10 (including shipping), but I have dozens of both the SAE and the metric fitting that I already own. I would appreciate hearing from anyone as to which fitting I need to use.......SAE or Metric.?
------------- Frank
Posted By: Duane in Indy
Date Posted: June-23-2018 at 4:46pm
To add more confusion it could be 1/16 npt. Get the old one out and compare it to your stash.
Date Posted: June-23-2018 at 4:55pm
Duane in Indy wrote:
To add more confusion it could be 1/16 npt. Get the old one out and compare it to your stash. | Or find a Yamaha outboard web site.
Posted By: Dziadzi
Date Posted: June-23-2018 at 5:08pm
Both the metric and SAE look similar. I wish it were that easy. I just would like to know if Yamaha used metric or SAE fittings.
Thanks
------------- Frank
Date Posted: June-23-2018 at 5:09pm
The internut says it's a metric M6x1.0
Posted By: Dziadzi
Date Posted: June-23-2018 at 5:12pm
I have been to the Yamaha website. No information about that topic.
------------- Frank
Date Posted: June-23-2018 at 5:17pm
I think you are going to have to remove the broken one before you install the new one. Maybe you could look at it then and decide which one to use. Yamaha site may show where it is but I think you would be lucky if they gave any info on sizes.
Posted By: Dziadzi
Date Posted: June-23-2018 at 5:19pm
Thanks, Duane. May I ask where it says that?
------------- Frank
Date Posted: June-23-2018 at 5:21pm
https://www.tinboats.net/forum/viewtopic.php?f=4&t=25340" rel="nofollow - zerk
Posted By: Dziadzi
Date Posted: June-23-2018 at 5:22pm
The difference in the threads is indistinguishable to my eyes.
------------- Frank
Date Posted: June-23-2018 at 5:23pm
take one of the other ones out and compare it to new ones
Date Posted: June-23-2018 at 5:28pm
Dziadzi wrote:
The difference in the threads is indistinguishable to my eyes. |
If thats the case then either one will probably go in Metric is .039 pitch Sae is .036 pitch Metric .236 dia Sae .250 dia
Basically take your pick and see which one screws in the best.
Posted By: Dziadzi
Date Posted: June-23-2018 at 5:29pm
Thanks for that website, Duane..........I am going to try the metric. Good catch!
------------- Frank
Posted By: KENO
Date Posted: June-23-2018 at 6:46pm
Based on a fair amount of experience with Yamaha stuff with grease fittings, it's about 99.9% sure to be 6 mm.
Just think Ya-Ma-Ha Ja-Pa-Nese metric whether it's put together in Japan or any other country that they have plants.
