Low Pressure Fuel Pump
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=43060
Printed Date: November-15-2024 at 6:44pm
Topic: Low Pressure Fuel Pump
Posted By: shea.95
Subject: Low Pressure Fuel Pump
Date Posted: June-29-2018 at 1:04pm
I have a 2003 Nautique 196. A technician came out and said the Low Pressure Fuel Pump has bad pressure after running the boat at about 30 mph for about 2 minutes. The boat turns on and runs fine for a bit and then starves out after a bit and slows the boat down as it seems there is not enough fuel.
I replaced the low pressure fuel pump along and am having the same issue. The relay and fuse seem to be fine as the pump hums and vibrates a bit when the boat turns on. I am not sure where to go from here.
Thank you,
Andrew
Date Posted: June-29-2018 at 1:28pm
Andrew,
How did the "tech" determine the pump was a problem? Pressure gauge?
Posted By: shea.95
Date Posted: June-29-2018 at 1:52pm
Pressure gauge
Thank you,
Andrew
Posted By: Gary S
Date Posted: June-29-2018 at 2:51pm
I would check the anti siphon valve next like advised in previous post and if not the problem then pickup in the tank after that.
Date Posted: June-29-2018 at 3:15pm
Andrew,
Do you know where he put the pressure gauge in the fuel system and what the reading was? You could do it yourself but I agree with Gary about checking at the tank first.
Posted By: Gary S
Date Posted: June-29-2018 at 5:14pm
15 Year’s out of a throw away pump is pretty good Pete. I’ll bet most have been changed by now. There is a screen under the top cover but for 55 dollars it’s not worth messing with it. PCM has to get 200+ for their replacement though.
Posted By: shea.95
Date Posted: June-29-2018 at 5:29pm
Replaced low pressure fuel pump and the filter and still not working. High pressure pump is turning on. Boat still runs for 2 min at 34 and then bogs down
Thank you,
Andrew
Posted By: Gary S
Date Posted: June-29-2018 at 6:04pm
Posted By: shea.95
Date Posted: June-29-2018 at 6:55pm
Checked anti-siphon and that was the issue! Clogged with bugs and gunk. Thanks so much!
Thank you,
Andrew
