What is that noise?!
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4387
Printed Date: November-30-2024 at 10:43am
Topic: What is that noise?!
Posted By: Kovatz
Subject: What is that noise?!
Date Posted: August-06-2006 at 5:25pm
I have had an 81 nautique for 30 days and have been working on it since then. The claim was that it has been winterized and that it should fire right up. I was able to see it running on the ramp but not well enough to take to the lake with much faith. Its timing was way off and we were getting misfires coming out the top of carb. Replaced the harmonic balancer and condensor, cleaned the points and was able to time it and get it running smooth. I had feared fuel issues but it will idle with ease. Great, off to the lake....nope. I have a nasty ticking noise that sounds like it is coming from 1 or 2. An inspection of the valve springs, rocker arms and push rods show that all is well in my novice opinion. I am afraid of what that leaves but I thought I would throw it to the forum and see you all thought. Thanks in advance for any help. I took a video and will add to this topic a link for the experts to review. Thanks in advance
Posted By: GottaSki
Date Posted: August-06-2006 at 5:52pm
If it goes away when you close the engine cover, and you did the inspection, and all the rockers move the same amount, Fugetabout*t.
By '82 boat ticks since I got it in '96... waiting for it to frag so I can repower
still waiting...
River Rat to Mole
Posted By: Bob's2001
Date Posted: August-07-2006 at 12:31am
Could be an exhaust leak.
------------- Bob Ed
83 2001
Posted By: Atmspltr
Date Posted: August-07-2006 at 4:23pm
It could be a sticking hydraulic lifter. Try some Rislone oil additive...it does a good job of freeing up stuck lifters.
RB
------------- http://i73.photobucket.com/albums/i201/Atmspltr/frontboat.jpg - 67 Mustang Resto-Mod
Posted By: David F
Date Posted: August-07-2006 at 4:25pm
Could be a mis adjusted rocker arm, piston slap, bad lifter, exhaust leak.
Disconnect the plug wire from offending cylinder to rule out piston slap. If noise goes away, then you have piston slap.
