intermittent starting issue
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4503
Printed Date: January-16-2025 at 4:53pm
Topic: intermittent starting issue
Posted By: Martinique
Subject: intermittent starting issue
Date Posted: August-14-2006 at 3:27pm
I have an 86 CC Martinique and every so often I turn the key and nothing happens. Yes the boat is in neutral and the ignition button is on. I have replaced the key ignition and still have the same issues. After turning the key a few times it will start right up. Any ideas.
Posted By: Tim D
Date Posted: August-14-2006 at 3:39pm
Check the little wire going to the starter, which is the ignition wire, and make sure you have 12 volts. You might have to put a relay in so you have exactly 12 volts.
------------- Tim D
Posted By: 79nautique
Date Posted: August-14-2006 at 4:18pm
might have a neutral safty switch going bad or the kill switch lanyard going bad if your's has one. When it happens again try moving the shifter into reverse and back to neutral then hit the key, might just be a slight cable adjustment is needed. Are the guages resetting when the key is in the on postion? look at the tach and it should go to Zero with the key on if not then let us know and we can tell you where to start looking.
Tim.... ford starters don't have an extra wire going to them just the heavy battery cable. A chevy starter would though.
Date Posted: August-14-2006 at 4:25pm
79Nautique...thanks for the ideas I don't have a lanyard switch but everytime this happens I do put it in gear and hit the ignition button and never figured out which one is the culprit but I think you may have something with the neutral safety or cable adjustment. How do I fix this? The gauges do reset so I know I have power and the key works.
Date Posted: August-14-2006 at 6:54pm
to narrow it down to the neutral safty switch you can by-pass the switch by connecting both wires to the same post. JUST be for warned that the engine will start in gear and move if not in neutral. On the drivers side of the tranny there will be two white wires attached to the tranny, it looks like a sending unit, that's the neutral safty switch. Unscrew the wires and attach them to the same post that will by-pass the switch. Take it out and see if the problem is still there. Just connect it back the way it was before you let someone else take the boat out.
But first you sould visually inspect the shift lever and cable movement. Move the morse control back and forth between forward and reverse and neutral with the boat off and make sure that the lever on the tranny is centered in the neutral postion each time there are cast letters on the housing to indicate where it is you can do it yourself or have someone move it while you watch it or move it then check it. If it doesn't look like it is going to the center spot then the cable needs adjusted so that it does.
Date Posted: August-18-2006 at 4:04pm
I just replaced the neutral safety switch looks like it solved the problem but won't know for sure until I run it a couple times this weekend
