prop
Category: CorrectCraftFan.com
Forum Name: Help CorrectCraftFan.com
Forum Discription: Learn how you can contribute to CorrectCraftFan.com
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=453
Printed Date: November-24-2024 at 11:15am
Topic: prop
Posted By: lectrician89
Subject: prop
Date Posted: June-07-2004 at 7:47pm
I have a 69 Mustang. I recently did the heads and it seems to run great. However, I can't seem to get more than 3300 rpm in the water. Could I possibly need a different prop? I don't know what I have, or what it should be. In neutral, I could redline it easily. Any suggestions?
Posted By: Tonali_III
Date Posted: March-15-2008 at 8:51pm
I would suggest that you remove the prop and take it to your local prop shop. The diameter and pitch should be stamped on the prop. You may need a shallower pitch.
What engine are you running? What rated horsepower at what RPM? What is the rated torque?
Also, Michigan Wheel (www.miwheel.com, I think) has a propellor analyzer. You can give the engine spec for your boat and it's intended use and they will make a suggestion as to the pitch you need.
Good Luck
------------- http://correctcraftfan.com/diaries/details.asp?ID=553&sort=&pagenum=1" rel="nofollow - 1974 Southwind 20 <a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6752" rel="nofollow">1972 Mustan
Posted By: 1969cc
Date Posted: March-15-2008 at 10:35pm
Hi
You might want to post in the Engine repair forum. You will get more replies. Need more info as listed above. Engine, prop size. Tranny oil level,etc.
------------- If you see light at the end of the tunnel you might be looking the wrong way
http://correctcraftfan.com/diaries/details.asp?ID=3674 - 69 Mustang
