Carb Port Question?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4740
Printed Date: March-11-2025 at 1:05am
Topic: Carb Port Question?
Posted By: JHadji
Subject: Carb Port Question?
Date Posted: September-11-2006 at 1:11pm
I have a 1988 w/the 351w. The Holley Carb has an open port sucking vacuum (red arrow). There is a bra$$ nut and screen insert. I'm guessing for a vacuum advance mechanism? I lean to plug it up, but was wondering if this is normal or is something missing? Thanks for any insight.
1988SkiNautique2001
Posted By: GottaSki
Date Posted: September-11-2006 at 1:36pm
you guessed...poorly.
If you plug it up, it will burn out the electric choke, the air keeps the element cool.
It should not be pulling in big air, just a little, else something is amiss.
River Rat to Mole
Posted By: JHadji
Date Posted: September-11-2006 at 4:38pm
Thanks Tom - saved me from myself
1988SkiNautique2001
Posted By: delhidream
Date Posted: September-11-2006 at 5:16pm
If you have avacuum leak around the choke, mine did the same thing after rebuild and I found that the gasket around the port on the back side was no longer stuck to the choke mechanism. I figured there must of still been some carb cleaner on it and the stick um on the cork gasket didn't bond, because I remembered putting it on but I didn't double check it when rea$$embling.
