Timmy Tee Question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47415
Printed Date: March-09-2025 at 10:07am
Topic: Timmy Tee Question
Posted By: JPASS
Subject: Timmy Tee Question
Date Posted: May-05-2019 at 5:35pm
This is not a CC related question, but it does involve the Timmy Tee, so I figured I'd ask it here.
Wifey and I have been shopping for a bigger boat (32'+) lately. This boat will be wet slipped in the salt water. Salt water and manifolds and risers don't mix as we all know.
Would it be possible to install the Timmy Tee and flush the exhaust and manifolds with fresh water while the boat sat in the slip at the marina? It appears to have a valve at the through hull. So my logic was to install the TT after the valve.
The exhaust exits on the sides, slightly above the water line.
Posted By: MrMcD
Date Posted: May-05-2019 at 7:26pm
With a Timmy T and a fresh water hose attached you would get much more fresh water into the system but the boat is still in water and I bet some salt water would be sucked in also but I have never tried what you wish to do. Your pump will suck from the easiest source.
Date Posted: May-05-2019 at 7:46pm
JP, As long as you close the sea cock, I don't see a reason the TT wouldn't supply the fresh water to the engine.
Posted By: SNobsessed
Date Posted: May-05-2019 at 8:00pm
I would set it up so you can't forget to open your seacocks back up, Otherwise it could end up costing you way more than manifolds.
Maybe tie a cord between the ,two or something else very obvious like that.
Posted By: JPASS
Date Posted: May-06-2019 at 8:08am
Forgetting them closed is definitely an issue. I would think my procedure would be to park the boat, hook up the hose, shut the valve, fire up engine, run for a minute or so, then remove hose and open valve. Repeat for other motor.
Good to know it's possible to do. I would think it would help prolong the life of the manifolds a bit.
Posted By: Smithfamily
Date Posted: May-06-2019 at 9:44am
What kind of boat are you looking at? Where will you keep it? Jerry
------------- Js
Posted By: JPASS
Date Posted: May-06-2019 at 11:32am
Smithfamily wrote:
What kind of boat are you looking at? Where will you keep it? Jerry |
We've looked at a few different makes and models. Boat will be between 32'-35'.
Looking to keep it on East Coast near New Smyrna beach area.
Posted By: 80SN Barnfind
Date Posted: May-06-2019 at 3:00pm
JP,
My twin inboard Sea Ray has a T on each sea strainer.
------------- Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
