123 40 PMC Trans
Category: Buy and Sell
Forum Name: Boat Parts For Sale
Forum Discription: Parts for sale only
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47425
Printed Date: November-22-2024 at 8:43pm
Topic: 123 40 PMC Trans
Posted By: tarpon32
Subject: 123 40 PMC Trans
Date Posted: May-07-2019 at 11:03pm
In a few days swapping the pmc 40 for an 80. Ford motor, works fine except for the whine .Can anyone use the trans when it is removed? Free, not shipping, you pick it up. Randy. Lower Alabama
Randy
Date Posted: May-08-2019 at 8:41am
sending a pm
Posted By: gun-driver
Date Posted: May-09-2019 at 11:01am
Can't wait to see the journey this makes on it's way to the North, through the CCF underground railroad.
Posted By: ScottZ
Date Posted: May-10-2019 at 7:36am
If Tim does not get It I will take it. I am in Clanton and will be headed South next Thursday.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Posted By: tarpon32
Date Posted: May-25-2019 at 9:36am
Received the PMC 80 due to backorder, getting ready to start the switch on the 1990 nautique. I can use any advice,. looks like remove the engine cover, muffler, starter, drive shaft, bell housing.. Who ever wants the 40, I will post when ready for pickup, again works fine using it this weekend shifts smooth, just can not ignore the whine.. Randy
Randy
Date Posted: May-25-2019 at 10:03am
Swap is straightforward... motorbox, rear floor panel, (rear seat if it’s in). Muffler, cable and any water hoses in the way. Then unbolt from coupler, and the mounts from the cradle (leave mounts on transmission. Bottle jack under an exhaust manifolds to take the weight off the mounts. Then the bellhousing bolts and slide it back. You could also pull it with the bellhousing on it, which requires removal of the front lower panel first... has to come with either way for the damper change. About a 20min job if you’re hustling.
Please PM me when the 40a is out- I have a home for it!
Trbenj@gmail.com
Date Posted: July-09-2019 at 1:57pm
Any update?
