Oil pressure drops
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47514
Printed Date: October-06-2024 at 8:28am
Topic: Oil pressure drops
Posted By: beebe
Subject: Oil pressure drops
Date Posted: May-27-2019 at 6:33pm
I have a 1986 ski nautique 2001. Last time we took it out, the oil pressure would go to zero upon acceleration from stopped. We could cruise just fine if we accelerated slowly. But pulling a skier up to speed the pressure was just staying at zero, and I ended up backing off and dropping a skier in the water because I didn't want to damage the engine. Then we started up and cruised back to the dock with gradual acceleration just fine.
I just went out and cranked it up to see and this happened. You can see it goes up to 40 psi then back to zero then up to 40 again.
https://youtu.be/Rv0y5_Y-3ic
This boat had a new oil pressure sensor a year ago because it wouldn't get oil pressure while cranking. Turns out it the previous owner had installed the wrong starter on it and the engine was turning backwards, hence no pressure. This is fixed and we've put quite a lot of hours on the engine since with no problems until this.
Other odd thing is it drops completely to zero and suddenly pops back to good pressure. There's no in between.
Any ideas? What should I check?
Thanks
Date Posted: May-27-2019 at 6:56pm
Roger, I wouldn't trust what the gauge is telling you. From your picture, I suspect a gauge/sender/electrical problem. Installing a mechanical gauge would confirm the true pressure.
https://youtu.be/Rv0y5_Y-3ic" rel="nofollow - Here's a direct link to your video
Posted By: Fabcon
Date Posted: May-27-2019 at 7:30pm
+1
------------- 1976 Ski Nautique 351 Escort 1984 Barefoot Nautique (Parting Out)
Date Posted: May-27-2019 at 7:42pm
Roger, An additional thought is when the new sender was installed, was any type of pipe thread sealant used? The engine block is the ground source for the gauge so NONE should be used.
Also, I recommend cleaning up all connections in the gauge circuit.
Posted By: beebe
Date Posted: May-27-2019 at 7:48pm
Thanks, I'll try troubleshooting electrical a bit more and if necessary I'll run get a mechanical gauge and try that. Appreciate the help!
Posted By: gt40KS
Date Posted: May-27-2019 at 10:09pm
+1 on the electrical possibility. I seriously doubt the oil pressure could pop up and down so abruptly as the video shows. This to me is a very good indication of an electrical issue.
------------- JCCI 1995 Ski Nautique GT40
