Impeller lost chunks. No thermostat to stop chunks
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48003
Printed Date: March-06-2025 at 5:25pm
Topic: Impeller lost chunks. No thermostat to stop chunks
Posted By: Evilsizer
Subject: Impeller lost chunks. No thermostat to stop chunks
Date Posted: September-04-2019 at 11:16am
Hey guys. Just purchased the boat. A 78 Ski Nautique with the 351. My impeller is missing chunks. I checked the thermostat housing and found no thermostat was installed. Does this mean a total rebuild?
Date Posted: September-04-2019 at 11:27am
Andrew,
Rebuild of what? The RWP or are you thinking engine? Unless the engine was overheated and run for some time, I would say no. Keep an eye for signs of water in the oil. If you are thinking the RWP, then no. Just get a new impeller in it. A T stat would help too!
Posted By: GottaSki
Date Posted: September-04-2019 at 1:10pm
The Thermostat lets water out, not in
Check the status housing water inlet, it's inside dimensions are quite small
And check the exhaust manifold inlets
River Rat to Mole
Date Posted: September-04-2019 at 1:33pm
Ok. I was thinking the chunks would have went down the intake and into the motor
Posted By: Orlando76
Date Posted: September-04-2019 at 1:42pm
well actually it does both.
1976 Ski Nautique 351 Escort
Posted By: bfootr
Date Posted: September-04-2019 at 1:56pm
Don’t forget to check the water pump IINLET hose. When my impeller broke apart, I found the broken vanes there. Most folks including myself initially check downstream from the water pump. Often the broken vanes obstruct the water inlet side.
Posted By: Hollywood
Date Posted: September-04-2019 at 3:28pm
No
Date Posted: September-04-2019 at 3:35pm
No
I'm going with out!
Date Posted: September-04-2019 at 5:00pm
No
I'm going with out!
It’s gotta let it in to let it out. It doesn’t magically produce water.
Date Posted: September-04-2019 at 5:10pm
Do you eat with the same hole you ***************?
Posted By: KENO
Date Posted: September-04-2019 at 5:15pm
Sometimes I have my head up there though,as a matter of fact I think we all have at one time or another
Posted By: GottaSki
Date Posted: September-04-2019 at 5:43pm
huh, seems my careless brevity caused some seasons-closing consternations...
Permit me to rephrase...
Water exits the engine block through the tstat
Its presence could only trap pieces exiting the block, but impeller chunks would rather plug inlets , then if get through skip the block entirely and go out the manifolds, as that is where the major flow and delta-p is.
in summary, Its a gazouta, not a gazinta
River Rat to Mole
Posted By: 96SNEFI
Date Posted: September-05-2019 at 2:04am
So thinking about this in the fuel lines...there are little screens here and there in the fuel path.
Could there be a way to screen the pipe from the RWP exit before it "gazinta" the engine thereby capturing the chunks?
