Change oil
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48066
Printed Date: November-15-2024 at 6:46am
Topic: Change oil
Posted By: Stuckers Nautique
Subject: Change oil
Date Posted: September-19-2019 at 12:42pm
I am new to the boating I have a 1994 sport Nautique with a 351 wondering what type of oil to use it and if it be a good idea to use a better type of oil.
Posted By: Jonny Quest
Date Posted: September-19-2019 at 1:34pm
What I use:
Filter
K&N 3001
Oil
Mobil 1
15W-50
Valvoline VR-1
20W-50 (full. Synthetic)
Royal Purple
HPS 20W-50
Need ZDDP “zinc” level 1,200+ ppm (for flat tappet cam)
I do a full fluid change (engine & transmission) at the end of each season for a cold lay-up.
Date Posted: September-19-2019 at 1:54pm
OK thanks what type of transmission oil would you recommend then
Date Posted: September-19-2019 at 2:31pm
Most will recommend Dextron III. I use a fully synthetic that is Dextron III compatible. Some will say that the fully synthetic is too "slick" and that one should stick with the Dextron III. No issues with my rig with the full synthetic after several years of use. I use the Royal Purple MAX ATF. The PCM 1.23:1 tranny takes 2 quarts.
(your mileage may vary)
Date Posted: September-19-2019 at 2:40pm
Thanks
Posted By: Otto Throttle
Date Posted: October-13-2019 at 6:29pm
How do you get the fluid out of your tranny?
Thanks
Otto
Date Posted: October-13-2019 at 6:54pm
Thanks
It's sucked.
Posted By: KENO
Date Posted: October-13-2019 at 7:25pm
Here's a blast from the not too distant past in the link below Otto
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=47120&title=transmission-fluid-change" rel="nofollow - link
Date Posted: October-13-2019 at 7:39pm
Engine AND trans:
Posted By: Hollywood
Date Posted: October-13-2019 at 11:19pm
The Topsider is a POS get the mityvac
Posted By: MrMcD
Date Posted: October-14-2019 at 4:10am
You can also run Delo or Rotella or Castrol Diesel Engine Oil, comes in 15-40.
It works fine in flat tappet engines. ( standard Lifters, not Rollers )
It is about 1/2 the cost of the fancy oils but works and is available everywhere, like Walmart.
For a Filter both Wix and Hastings offer good high quality filters.
Wix is available at all Napa Parts Stores.
Date Posted: October-14-2019 at 11:03am
Thank you! I know an owner who has never changed his....so in three years I have not changed mine. I just want to do it before she snuggles in to her winter slumber.
Otto
Date Posted: October-14-2019 at 11:04am
Any real downside to doing it cold?
Otto
Posted By: quinner
Date Posted: October-14-2019 at 12:56pm
Yes, takes forever, warm oil pumps or drains much better.
Trans does not matter.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Date Posted: October-14-2019 at 2:00pm
Ok good I will do the tranny today. I always change oil/filter in the spring.
Thank you!
Otto
Posted By: MrMcD
Date Posted: October-14-2019 at 2:55pm
It is better to have the engine sit on clean oil all winter. You should turn it over once clean oil is in there to distribute the clean oil through the engine. Used oil has contaminants in it that can etch an engine bearing when the boat sits for long periods.
If you are draining it with a cold engine just be patient. Open the drain hose into a bucket and leave it for a few days. Then add your new oil. It will drain, it will just take hours rather than minutes.
Date Posted: October-14-2019 at 5:59pm
Yes, old oil will build up acids that can etch bearings BUT, it's time (hours) on the engine that causes the build up. Going by hours and not months is better for determining if an oil change is needed. Also, todays oils do have additives to keep the acids in check that oils way back did not have.
Posted By: MrMcD
Date Posted: October-14-2019 at 6:23pm
I agree Pete and I admit that if my Boat only has 20 hours on it this year on my fresh oil it will probably run on that oil again next year.   But if it has dirty oil change it before storing.
