Hose question.
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48078
Printed Date: November-15-2024 at 6:58am
Topic: Hose question.
Posted By: Mpost
Subject: Hose question.
Date Posted: September-24-2019 at 11:01am
My 98 GT40 used to have a heater installed. Previous owner disconnected it and I don't plan to use it either. My question is there is a hose running from a T with a temp sender down to the block drain hole on the side of the engine. Can this hose be disconnected and the T plugged or removed ant eh sender just mounted in the elbow feeding the T. I want to install the drain valves discussed in an earlier thread this week. Its a pain dealing with this hose when draining the block.
Thanks for any help you can provide.
T
Block drain
------------- 84 SN Sold 98 SN Lund Pro V 1975 Alumacraft
Date Posted: September-24-2019 at 11:11am
Yup, you can plug the holes. The tee can be removed entirely and the temp sender returned to the intake manifold.
Posted By: gun-driver
Date Posted: September-24-2019 at 11:18am
Whaaaaat, Minnesota and you don't want the heater. Heck I used mine this past weekend to warm my feet and my daughter was wrapped in a towel with the hose feed underneath. Best option available.
Posted By: GottaSki
Date Posted: September-24-2019 at 11:52am
Yeah, heater is the best.
River Rat to Mole
Posted By: Mpost
Date Posted: September-24-2019 at 3:16pm
Were tough up here! don't need no stinking heater
Posted By: Mpost
Date Posted: September-24-2019 at 3:19pm
TRBenj wrote:
Yup, you can plug the holes. The tee can be removed entirely and the temp sender returned to the intake manifold. | Thanks Thought so just wanted to be sure.
