An interesting read
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48085
Printed Date: March-06-2025 at 2:07pm
Topic: An interesting read
Posted By: KENO
Subject: An interesting read
Date Posted: September-25-2019 at 9:48pm
At least it was interesting to me and I figure MrMcD and a handful of others will probably find it interesting also.
Just to be perfectly clear, I know that boats don't run in the sandy desert
There have been a couple of chewed up distributor and cam gear threads recently though.
https://www.fordmuscle.com/tech-stories/engine-forensics-inside-a-sbf-after-completing-the-baja-1000/" rel="nofollow - link
Posted By: MrMcD
Date Posted: September-25-2019 at 10:24pm
Thanks Ken, that is a good read for guys who like engines.
When you have distributor gear failure you always need to check the oil pump to see if it is loading the drive shaft excessively.   Turning the distributor is a no load situation but turning the oil pump can be very high load most often on cold start ups with thick cold oil.
They might be asking that gear to work harder than it is designed for.
Posted By: RealDeez
Date Posted: September-25-2019 at 11:10pm
I don't know much about engines but I find this stuff quite interesting.
Lake James, IN
93 Sport Nautique
Posted By: Mille1sj
Date Posted: September-26-2019 at 2:21pm
From my understanding of bronze distributor gears, it’s not uncommon for them to wear out in race applications. I am surprised there was no mention of changing to a composite gear.
Posted By: GottaSki
Date Posted: September-26-2019 at 6:08pm
And they remark getting a new oil pump, but unclear if it's high volume or std
River Rat to Mole
Posted By: Fabcon
Date Posted: September-26-2019 at 8:01pm
Nice read
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
Posted By: Gary S
Date Posted: September-27-2019 at 2:46am
I have heard in the past that Fords do not need a high volume pump, have you ever heard that?
The only thing I question is their use of a gasket on the manifold ends, I thought it was standard procedure to use silicone gasket maker, they must have a reason not to use it.
Posted By: GottaSki
Date Posted: September-27-2019 at 7:03am
Yeah I was surprised to see the cork also!
Indeed rtv has been the solution for decades. I've also seen dimpling the rails done.
River Rat to Mole
Posted By: Mille1sj
Date Posted: September-27-2019 at 10:03am
I installed a high volume oil pump in my 302 I rebuilt for a 77 Skit Tique last winter. I’m sure a standard lump would have been fine, I just wanted to ensure I had good flow at high rpm’s.
Posted By: KENO
Date Posted: September-27-2019 at 11:49am
With a 351 Pleasurecraft and the stock oil pan, you don't have to worry about using a high volume pump like say a Melling M-83HV because the pan won't fit with the pump in place,
The extra depth of the pump body keeps the pan from seating on the block up front where the pump is.
Posted By: JoeinNY
Date Posted: September-27-2019 at 1:26pm
Not that I recommend a high volume pump, as the extra stress on the dist/cam gear for the fords is imho more likely to break than save your engine. However, I had to go back and check but according to my records I am running a melling 10833 - high volume standard pressure oil pump on my 83 ski nautique. It has the stock pan as far as I remember, I bought some later gt40 ones but they didnt clear my stud girdle, so I went back to the original. The block however is not from 83, it is a roller block so maybe 95 vintage.   ?
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: Mille1sj
Date Posted: September-27-2019 at 1:37pm
I was able to use the stock pan with mine, I would have to verify the model but I believe it’s a Melling 68HV. I ended up getting a composite distributor gear so I am less concerned with stress on the gears. I only have a few hours on the engine since the rebuild but so far it looks good.
Posted By: KENO
Date Posted: September-27-2019 at 6:08pm
302 and 351 pumps and pans don't fit each other so that's kind of an apples and oranges comparison but good info for somebody with a 302 to have
Posted By: DHMcFadin
Date Posted: September-27-2019 at 8:23pm
Very cool read! Thanks for sharing!
1999 Longhorn Nautique
1995 Nautique Super Sport
https://www.instagram.com/longhorn_nautique/" rel="nofollow - https://www.instagram.com/longhorn_nautique/
