Oil Filter
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48103
Printed Date: November-15-2024 at 8:11am
Topic: Oil Filter
Posted By: Bertie
Subject: Oil Filter
Date Posted: October-01-2019 at 1:57pm
I'm having some trouble finding the right oil filter for my 2002 216 Nautique Air. New to me this year and prepping for winter...
Does anyone know the WIX oil filter part number? PCM Excalibur 330.
I would obviously look at current one but I am not close to the boat.
Thank you,
Posted By: KENO
Date Posted: October-01-2019 at 3:18pm
Assuming it has a remote mount oil filter, it's a Wix 51515.
It fits a lot of Fords but it's the remote mount filter PCM used on the Excalibur 330
Posted By: quinner
Date Posted: October-01-2019 at 5:00pm
Ken is correct if you have the remote filter, it's a ford filter, Motorcraft FL-1A or Wix as noted above. Be careful to check for the old gasket not coming off with the the old filter before installing new.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Posted By: Bertie
Date Posted: October-01-2019 at 6:04pm
Same if its the Chevy motor... I know it's not the ford.
Posted By: KENO
Date Posted: October-01-2019 at 6:09pm
The 51515 is a filter that fits a lot of Fords and it's also used on your Excalibur 330 if you have the remote mounted filter which you most likely do.
If Quinner says it's right it's right
Posted By: quinner
Date Posted: October-02-2019 at 12:38pm
See that thing in front of the port side riser, that is your remote oil filter, the filter it uses is a Ford filter noted above.
