Repack rudder
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48106
Printed Date: November-15-2024 at 6:47am
Topic: Repack rudder
Posted By: wromer
Subject: Repack rudder
Date Posted: October-02-2019 at 6:55pm
I have some play in my rudder and I'm thinking of repacking it. I'm not sure of the correct size packing to use, its a 1996 SN any help would be appreciated.
------------- All gave some......Some gave all
Posted By: Gary S
Date Posted: October-02-2019 at 7:34pm
If it's not leaking and if it is you should just adjust the packing,repacking will not remove any rudder slop
Posted By: wromer
Date Posted: October-02-2019 at 7:46pm
Gary, Rudder slop, good description, Its not a lot and my thoughts were repacking it would snug it up. If that would not take the slop out what would ?
Date Posted: October-02-2019 at 8:44pm
| William,
Are you sure the slop is between the rudder shaft and port and not in the cable, helm and linage?
Posted By: wromer
Date Posted: October-03-2019 at 12:19pm
I have the boat on the trailer and the rudder can be moved both side to side and front to back, Not much maybe a 1/4 inch. I'm not sure if that is to much for a 23 year old boat ?
Date Posted: October-03-2019 at 1:07pm
William, Unless the port is allowing water into the boat, I don't feel you have a problem.
Posted By: wromer
Date Posted: October-03-2019 at 3:01pm
Thanks for the replys, I'm guessing that is normal wear for the years on the boat so I'll just keep an eye on it .
Posted By: GottaSki
Date Posted: October-03-2019 at 3:36pm
Wouldn't hurt to verify there is grease in there so the wear stays as it is and doesn't accelerate
River Rat to Mole
Posted By: MrMcD
Date Posted: October-03-2019 at 3:46pm
I had mine apart a few years ago to replace the prop shaft and get the strut back in line. I am sorry but I don't remember the packing size, packing is cheap so buy both 3/16 and 1/4" so you have it on hand when or if you do this job. I added a grease zerk to mine while it was apart. Makes it easy to pump a little grease in to keep the shaft lubed. Although your note has me thinking it has now been 4 years since I added any grease.
