Replacing panel breaker buttons
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48145
Printed Date: November-15-2024 at 8:04am
Topic: Replacing panel breaker buttons
Posted By: DockDoc
Subject: Replacing panel breaker buttons
Date Posted: October-14-2019 at 3:42pm
Not sure how much sacrilege I'm performing here... I don't have much faith in these OG '93 breaker buttons on the dash. They've worked OK, but the terminals look corroded, and the plastic is failing (one broke when I pushed it recently).
Found https://www.amazon.com/gp/product/B000MMFIZS/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1" rel="nofollow - these switches on amazon, tried one out. Had to expand the hole a tiny bit but no big deal, otherwise it was plug and play and feels very sturdy. I got the rubber boot as well although don't think I'll bother with it, too sticky feeling and attracts dirt/dust.
Any reason not to replace all 10 breaker buttons with these? They're pretty cheap, very solid feeling. I realize they're not breakers themselves, but I've already installed a new spade fuse bus under the dash and plan on wiring power from that (via a nice new 8 gauge wire from the battery) to these new switches so that shouldn't be an issue.
One installed with rubber boot:
------------- 1993 Sport Nautique PCM 351w, no ProTec
Posted By: gt40KS
Date Posted: October-15-2019 at 2:39pm
My dash - I'm one of those that doesn't necessarily follow that hardcore line of keeping it original though.
They work extremely well and were relatively inexpensive. New panels were carbon fiber I cut to fit the existing panel openings. Having said that, Carling switches are a bit more modern looking. The older style toggles you found have sort of a retro look, so I suppose it's a matter of your personal aesthetic taste.
------------- JCCI 1995 Ski Nautique GT40
Posted By: MrMcD
Date Posted: October-15-2019 at 3:22pm
Your dash looks professionally done. I too worry about those push button switches. I expect one to break nearly every time I touch them.
Posted By: DockDoc
Date Posted: October-15-2019 at 3:56pm
Nice, yeah I think that looks great. At some point I'd like to replace the panels as well, both sides are cracked and barely held on with crappy little screws. I was thinking some black anodized aluminum panels might do the trick.
Posted By: Jonny Quest
Date Posted: October-15-2019 at 4:43pm
Those are circuit breakers combined with the on/off switch. The toggle switch that you reference in the link is simply an on/off switch. Nautique Parts sells replacement breakers for an OEM replacement: When I refreshed the dash in my 1994 SNOB, I replaced all the breakers. Easy job.
https://www.nautiqueparts.com/product/20-amp-breaker/" rel="nofollow - LINK
2.5 amp – used on bilge pump and auto bilge pump 6-8 amp – used on blower 8 amp – used accessory 1 & 2 10 amp – used on navigation light, anchor light, and accessory 20 amp – used on ignition (main)
Posted By: DockDoc
Date Posted: October-15-2019 at 5:00pm
Yeah that's a good point, however I've run a new large gauge power line to a new spade fuse bus under the dash. The "ignition" switch supplies power to the rest of the dash, and is now fused through that bus (which is also still fused through the big breaker on the engine. So everything is still protected and these switches cost much less than the breakers (and I like them more).
Posted By: gt40KS
Date Posted: October-15-2019 at 5:44pm
Yeah JQ, I thought about the factory 'replacement' breaker/ switches at first also.... for about 2.2 seconds. Nope.. In short, bad design for the placement of the switches, IMO. If they were located in a closed panel in a closed location, such as a cuddy hold or cabin, I probably wouldn't mind them. But honestly, the whole style isn't my taste anyway ... they seem cheap and clunky to me. I know some don't care for the look of Carling switches either but as I always say, each to their own. Breaking the circuit at the switch is a good idea in theory I'll admit. I just don't like the execution in this case. To me the blade-based fuse block and switches I have now not only looks better (to me) but serves the same purpose and has decades of marine use with far less problems than the CC factory switches of this era. And really, when was the last time anyone popped one of those breakers anyway? And if you did, doesn't that point to an issue somewhere in the line? So resetting it and going on about your business doesn't really make sense and certainly won't fix the underlying issue. But I know for some it's a 'keep it original' thing. So once again, each to their own.
Posted By: Gary S
Date Posted: October-15-2019 at 6:45pm
Nothing to do with originality and I really hate to say this but those toggles look like something a Bayliner would use. Someone has found those push button breakers in the past here a lot cheaper than oem prices, and once again they have lasted 26 years. Doubtful your Chinese replacements will have the same life span.
Posted By: DockDoc
Date Posted: October-15-2019 at 7:05pm
Gary S wrote:
Nothing to do with originality and I really hate to say this but those toggles look like something a Bayliner would use. Someone has found those push button breakers in the past here a lot cheaper than oem prices, and once again they have lasted 26 years. Doubtful your Chinese replacements will have the same life span. |
Appreciate the honesty, if I could find the breakers super cheap I'd consider it for sure!
Posted By: Gary S
Date Posted: October-15-2019 at 7:35pm
I have looked but cant find Dreaming's thread. Maybe Ken can.
Date Posted: October-16-2019 at 1:13pm
The cost for the OEM style breakers is $9.95 each on www.NautiqueParts.com. Not too bad. They used to be $20+ each.
Posted By: DockDoc
Date Posted: October-16-2019 at 2:35pm
JQ |
The https://www.nautiqueparts.com/product/circuit-breaker-switch/" rel="nofollow - correct part , best I can tell, is $24 and up. They have cheaper ones with screw terminals used on older boats for around $10.
Anyway, this is a non-starter for me. These switches look and feel solid, their appearance is pretty subtle, and I'd rather a switch than the sketchy-feeling push on/off breakers.
Posted By: RealDeez
Date Posted: October-16-2019 at 7:37pm
[Redacted]
------------- Lake James, IN 93 Sport Nautique
Posted By: DockDoc
Date Posted: October-16-2019 at 8:08pm
RealDeez wrote:
I think relying on the engine breaker to keep my boat from starting on fire would be a little more risk than I would take... but everyone has their own level of paranoia.
My 93 pretty much needs the entire dash overhauled ... If I was going to go with switches I'd probably put a fuse panel or breaker panel inline for my own sanity. And at that point I might as well just by the OEM replacement breakers. 26 years and they're just now getting dodgy after 1400 hours on my boat...
If I'm still driving it in 26 years I'll probably be converting to some sort of electric drive or something because gas will be $50 a gallon or totally unavailable so... |
I'm not sure if you read my post above... I ran a new 8 gauge power and ground to a spade fuse bus under the dash (off the main breaker). Then the dash power comes off a fused spot on that bus. So everything is just as protected as it was before, except with new wiring.
Posted By: desertskier
Date Posted: October-16-2019 at 8:45pm
Not a big deal but I like being able to push the main ignition switch and kill power to everything as the system was originally designed. At the end of the day you will need to check the position of each switch. I guess you could add a switch somewhere to disconnected the system from the battery but the original one is pretty simple.
Posted By: RealDeez
Date Posted: October-16-2019 at 9:52pm
My bad. Wasn't so much didn't read as misread. My brain must have ignored the word "fuse" and just read spade terminal or something. Forget I said anything.
... post redacted
Posted By: gt40KS
Date Posted: October-17-2019 at 12:29am
Yep, one switch and everything's off.
Except for the automatic bilge.... that's wired (and fused) direct to the house battery.
Posted By: DockDoc
Date Posted: October-17-2019 at 12:33am
desertskier wrote:
Not a big deal but I like being able to push the main ignition switch and kill power to everything as the system was originally designed. At the end of the day you will need to check the position of each switch. I guess you could add a switch somewhere to disconnected the system from the battery but the original one is pretty simple. |
I'm not changing that design at all. The "Ignition" switch is still the only switch that gets constant hot from the battery. It supplies power to the rest of the dash (with the exception of the stereo in my boat, I gave that dedicated power from an accessory switch just to isolate it from dash components, intentionally). This is the same as factory wiring, I just replaced the power source with new / higher gauge wiring. Functionally identical.
Posted By: MrMcD
Date Posted: October-17-2019 at 2:16am
If you guys are in there and doing some dash wire work I hightly recommend upgrading the hot and ground wire that feeds the cigaratte lighter. I do not smoke but use my plug in for using my spot light at night. My spot light is a 1,000,000 candle power unit I have used in 3 boats now. First time I plugged it in to my 95 Nautique the current draw melted the cigarette lighter. I installed a new one with proper sized wires and it has worked just fine ever since. I think the light is about a 6-8 amp draw.
Date Posted: October-17-2019 at 12:33pm
DockDoc wrote:
I'm not changing that design at all. The "Ignition" switch is still the only switch that gets constant hot from the battery. It supplies power to the rest of the dash (with the exception of the stereo in my boat, I gave that dedicated power from an accessory switch just to isolate it from dash components, intentionally). This is the same as factory wiring, I just replaced the power source with new / higher gauge wiring. Functionally identical. |
So are you maintaining a fuse for each circuit or just relying on the one new ignition fuse? I was looking at your fuse box post and the box doesn't appear to allow for multiple inputs and looks like it is connected directly to the battery.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=48124&KW=&PID=577366&title=finally-got-around-to-adding-dedicated-wiring#577366" rel="nofollow - fuse box post
Date Posted: October-17-2019 at 5:53pm
desertskier wrote:
So are you maintaining a fuse for each circuit or just relying on the one new ignition fuse? | A concern of mine as well.
Date Posted: October-17-2019 at 6:05pm
Looks like a fuse for each circuit but no main breaker (at least pictured) on the dash side... relying on the main engine breaker?
The ignition breaker at the dash in the factory configuration isn’t appropriately named- it doesn’t just cut ignition power. It is protecting all 12v wiring coming from the battery (upstream of the key).
Posted By: DockDoc
Date Posted: October-17-2019 at 6:17pm
The ignition breaker at the dash in the factory configuration isn’t appropriately named- it doesn’t just cut ignition power. It is protecting all 12v wiring coming from the battery (upstream of the key). |
The way my dash is wired, the Ignition button (as you mentioned, inappropriately named) supplies power to all other dash components. Literally that's all it does, there's a hot input on the switch, which then daisy chains switched hot out to the other 9 dash switches. In the original configuration, those are all breakers of course.
With the new switches, the Ignition switch is still fused, but the other switches are not (exception: stereo, which is now independent).
The only downside to that is that if there's a short on one circuit, it will blow the fuse for the entire dash / Ignition switch. I.e., if the blower fan shorts out, it will blow the spade fuse under the dash and I won't be able to run the boat. I consider this a minor problem, just swap out the fuse and don't run the shorted component. Everything is still protected.
And the Ignition switch is wired same as original, i.e. constant hot comes off the engine breaker.
Date Posted: October-17-2019 at 6:59pm
Since you installed a nice fuse box I don't understand why you wouldn't use it. You could wire a fuse for each circuit according to the expected load. Instead you have a 50A fuse in series with a 20A (assuming you went with the original size) and then all your loads (except the stereo) in parallel. So if your bilge pump shorts it will need to draw 20 amps instead of the original 2.5 amps before the fuse blows. From the picture you posted of your exhaust it looks like you either added or moved your battery. If you added a battery did you install an isolation switch? If so you could use that switch as the master disconnect.
Posted By: DockDoc
Date Posted: October-17-2019 at 8:36pm
desertskier wrote:
Since you installed a nice fuse box I don't understand why you wouldn't use it. You could wire a fuse for each circuit according to the expected load. Instead you have a 50A fuse in series with a 20A (assuming you went with the original size) and then all your loads (except the stereo) in parallel. So if your bilge pump shorts it will need to draw 20 amps instead of the original 2.5 amps before the fuse blows. From the picture you posted of your exhaust it looks like you either added or moved your battery. If you added a battery did you install an isolation switch? If so you could use that switch as the master disconnect. |
Valid point! I was planning on wiring individual circuits to that panel, but I will do so more expeditiously, I hadn't considered that some of those circuits should be protected more conservatively. Easy enough to do and will clean up some of the wiring (it's a birds nest in there with all the daisy chained switches). Appreciate the insight.
Re the battery: I haven't put in a spare, that's the only battery and it's where it was when I bought the boat. Is that not the factory location? If not, where is the factory location?
Date Posted: October-17-2019 at 9:28pm
My mistake. I guess they moved the battery to the stern in the Sports. In the Ski's they are in a floor compartment in the front.
