Battery cable insulation?
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48652
Printed Date: April-05-2025 at 4:51am
Topic: Battery cable insulation?
Posted By: Wilhelm Hertzog
Subject: Battery cable insulation?
Date Posted: May-06-2020 at 11:08am
I'm replacing my battery cables (too much voltage drop across them). The only tinned copper cables I can find have silicone insulation. I understand that silicone is less resistant to chemicals like fuel and oil (which the cables may well come into contact with on occasion) than PVC. But I cannot get hold of tinned copper cables with PVC insulation. So which is preferable:
1. More corrosion resistant tinned copper cables in a less chemical resistant insulation (silicone), or
2. Less corrosion resistant bare copper in a more chemical resistant insulation (PVC)?
Thanks for any advice, much appreciated.
1982 Ski Nautique PCM351W RR II Velvet Drive 10-17-003 1:1 II PerfectPass Stargazer
Do not go gentle into that good night. Rage, rage against the dying of the light.
Posted By: Duane in Indy
Date Posted: May-06-2020 at 12:02pm
Right or wrong I used welding cable. Crimped and soldered the terminals. Used shrink wrap and then liquid tape. They will last plenty long for me. Welding cable is very flexible. I am sure there will be other opinions here also.
edit: per google**** Welding cable is approved for use in power supply applications in which the voltage does not exceed 600 volts. ... It makes a superior alternative to battery cable and can also be used in marine applications, but the insulation needs to be oil and water resistant as to not become saturated.Dec 11, 2018
        1978 Mustang (modified)
Date Posted: May-06-2020 at 12:14pm
Originally posted by Duane in Indy Duane in Indy wrote:
Right or wrong I used welding cable. .
Originally posted by Wilhelm Hertzog Wilhelm Hertzog wrote:
tinned copper cables .
This is what happens if the cables aren't tinned.
Yes, the OEM cable isn't tinned but that's why it's a common failure.
Date Posted: May-06-2020 at 12:20pm
You are so predictable.
Time period that this happened?? What type environment???
Date Posted: May-06-2020 at 3:22pm
So rather go for the tinned cable with silicone insulation and try to keep it clear of any nasties in the bilge?
Date Posted: May-09-2020 at 7:30am
Pete, are your comments in http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21931" rel="nofollow - this Battery Cables thread still best practice for connecting lugs to battery cable ends? I.e. both crimp and solder? I'm aware that soldered connections are not recommended elsewhere (because they make the wire stiff/brittle and prone to shearing, I believe), but is it different with battery cable?
Date Posted: May-09-2020 at 7:48am
Wilhelm,
I still like to solder lugs on battery cables just to keep any possible moisture out and create the best connection. In my opinion, the warning about the practice is for connection that are being flexed such as a wire running to an engine component.
