Mounting a swim platform
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48713
Printed Date: March-06-2025 at 4:19am
Topic: Mounting a swim platform
Posted By: 3rd_gear
Subject: Mounting a swim platform
Date Posted: May-21-2020 at 12:20am
Hey y'all, I've got a 78' ski nautique that originally came with a ladder but has been removed and holes "filled".... I've purchased an original teak platform with brackets ($150 for anyone wondering) and I'd like to mount it to my boat but I have no holes to guide where it should mount. I'm hoping someone can give me some simple measurements as to where I should mount it and if anyone has any tips on drilling holes or hardware type to use or sealants to apply that would also be very much appreciated!!
Date Posted: May-21-2020 at 8:52am
Jack, http://www.correctcraftfan.com/diaries/?yrstart=1978&yrend=1980&model=ski+nautique&state=&Forsale=&sortBy=Date+Updated&Submit=Search" rel="nofollow - Have you looked in the diaries for reference? Take a look
Posted By: SNobsessed
Date Posted: May-21-2020 at 9:20am
You can put tape on the gel coat before drilling to keep it from chipping. Start with small drill & go up in size in steps.
Do you have OEM brackets? I would think they pretty much dictate position.
Posted By: 3rd_gear
Date Posted: May-21-2020 at 9:34am
Yeah I have oem brackets and platform but how high is it seated from the bottom is what I'm looking for, I don't want it so high you can get on it or so low it drags. I figured there's a sweet spot someone might could give me a measurement on.
Posted By: 3rd_gear
Date Posted: May-21-2020 at 9:42am
It appears the diaries section may be better as a for sale section. I thumbed through a few pages and couldnt find much on rebuilding, mostly just selling.
Posted By: 67 ski nat
Date Posted: May-21-2020 at 10:34am
I might put boat in water with all your usual load and see where water line is compare that with pics in diary
Posted By: Gary S
Date Posted: May-21-2020 at 10:53am
After you drill the holes for the brackets counter sink the gelcoat so it does not develop stress cracks. You want the holes to resemble this- \ / more than this- I I
Posted By: 3rd_gear
Date Posted: May-21-2020 at 11:02am
Thanks for the advise, do you recommend any certain type of bit for this application or just anything and go slow?
Posted By: Jonny Quest
Date Posted: May-21-2020 at 11:29am
For through-bolting the platform, I would use 3M marine sealants: 5200 (permanent) or 4200 (removable)
Posted By: 3rd_gear
Date Posted: May-21-2020 at 11:33am
Posted By: Duane in Indy
Date Posted: May-21-2020 at 11:52am
If it were mine : I would make up some nut plates instead of just using nuts and washers. Maybe 1/4 X 2 X 2 aluminum plates. You could even make them long enough to capture both holes in one piece. Thru drill these and use lock nuts and washers also. These will spread out the load and help from cracking. Just one of many methods.
Posted By: Gary S
Date Posted: May-21-2020 at 11:54am
3rd_gear wrote:
Thanks for the advise, do you recommend any certain type of bit for this application or just anything and go slow? |
Just go slow using a small bit to drill a pilot hole. Measure twice drill once
Posted By: 3rd_gear
Date Posted: May-21-2020 at 12:04pm
Would you use sealant in the holes themselves or on the inside of plates...or both?
Date Posted: May-21-2020 at 12:24pm
Smear it everywhere. 4200 so it is easier to remove
Posted By: 3rd_gear
Date Posted: May-21-2020 at 12:31pm
Cool I think I got it....put boat in the water....mark where I want it to sit....drill small holes while stepping it up slowly....round over gelcoat edges to prevent cracking....use a mounting plate on inside to disperse weight evenly and use 4200 marine sealant everywhere......I think I'll have this thing on tomorrow then...just in time for the weekend fun!!
