Quick Fuels Carb for 351 on 87 Dominique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48716
Printed Date: March-06-2025 at 3:51am
Topic: Quick Fuels Carb for 351 on 87 Dominique
Posted By: illiniball2000
Subject: Quick Fuels Carb for 351 on 87 Dominique
Date Posted: May-22-2020 at 5:51pm
Thinking of switching to a Quick Fuels carb and using my Holley as a back up. Looking at M600 and was wondering what others have had to do to make it work. I know someone local to me said they had a braided fuel line made. Just curious so when I do it I want to have everything I need. Thanks
------------- Beer is my friend 87 Dominique Had 67 Starflite
Posted By: beretta5spd
Date Posted: May-22-2020 at 6:57pm
The quick fuel is awesome. Johnny Quest walked me through the little details of the swap. Here's the main takeaway:
Be damn vigilant in making sure no foreign material gets up into the float bowls. Make sure your hoses that you cut don't have any leftover material on the edges, etc.
Both of us had the unfortunate scenario where the float bowl stuck on the secondary and started to dump fuel down the secondaries. Scary situation. His was a manufacture error.... mine was installer error. Since then I cleaned out the secondary float bowl and it's been perfect.
Parts needed:
Quick fuel m600 Sierra 18-8115 fuel line to go from fuel pump to carb probably a spacer for the spark arrester.
Here's my thread... which actually won't help you that much but you can see it hooked up to a 95 351. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=48109&PN=3&title=1995-pro-boss-pro-tec
You may need an adapter fitting to get from your fuel pump to the sierra line.
Dwight
------------- 1996,1997 Sport Nautique 1986,1992 Ski Nautique - Sold 1995 Sport Nautique - Current
Posted By: Jonny Quest
Date Posted: May-22-2020 at 7:24pm
It should really be plug-and-play for the most part. The M-600 is based on the Holley 4160 design, so not much tweaking needed. I would go with a flexible fuel line as it makes the install easier. The QF should be good to go right out of the box. Not much adjustment needed. As noted above, my first QF had a small piece of brass metal shaving that got caught between the secondary needle and seat -- making the fuel to the secondaries float bowl not shut off properly. The fix was super easy as QF sent me a new needle/seat assembly. Great carbs.
https://www.skidim.com/prodinfo.asp?number=DIMRPFL" rel="nofollow - LINK to Flexible Fuel Line
Posted By: trice
Date Posted: May-22-2020 at 10:25pm
Just completed an M600 install on my 87 SN. -Sierra fuel line PN 18-8115 ($56.61 at wholesale marine) is perfect and a direct fit at the pump and the inlet bowl. USCG approved too! -To maintain an Inlet screen filter like used on the stock Holley, I used Holley PN 26-141 on the M600 bowl inlet. These somewhat “generic” screen filters must be trimmed to fit just right behind the Inlet fitting. -My original flame arrestor fit the M600. No interference with the M600 float adjusters. -Removed the M600 choke ground wire and used the choke ground wire in the original harness. -Had to adjust the front float level and leaned the idle mixtures slightly.
------------- 87 SN
Date Posted: May-23-2020 at 2:05am
Thanks for the responses. Just what I needed. Now I just need to go ahead and order one.
Posted By: SWANY
Date Posted: May-23-2020 at 11:42pm
illiniball2000 wrote:
I know someone local to me | Geez I see how it is.... buddy, friend, another CCF member would have been better😁
Date Posted: May-24-2020 at 1:51am
Haha Yep probably. I didn’t want to scare people off from offering advice.
Date Posted: May-25-2020 at 2:33pm
Again thanks for the info. Did the new carb come with the gasket between carb and intake?
Posted By: trice
Date Posted: May-25-2020 at 3:14pm
Posted By: zwoobah
Date Posted: May-25-2020 at 11:21pm
Just installed mine last week. I already had flexible A1-15 fuel line in place. Had to adjust my throttle linkage cable a bit, then set float levels and tweaked the idle screws. I had never installed a large engine carb before and this was surprisingly easy. My boat now starts faster and has a bit more power.
The quick fuel comes with a fuel line adapter installed. I removed this adapter and ran the banjo fitting/bolt that was already in my boat.
------------- 1968 Mustang 16 - 351W powered
Date Posted: May-26-2020 at 3:51pm
thanks again everyone. It should arrive by this weekend so hopefully I can get it installed
