Motor mounts
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48719
Printed Date: March-06-2025 at 4:14am
Topic: Motor mounts
Posted By: philip
Subject: Motor mounts
Date Posted: May-22-2020 at 9:36pm
I need to pull the Chrysler engine out of a mustang what part of the motor mounts Do I remove. Philip
------------- philip thompson
Date Posted: May-22-2020 at 10:10pm
Philip, Probably the easiest is to remove the lag bolts in the stringers and pull the mounts out along with the engine.
Date Posted: May-22-2020 at 10:18pm
Philip, I noticed no one welcomed you to CCfan so, welcome. How about some pictures of the project.
Have you been able to figure out what the hole is for next to the oil pan flange? Is it blind?
Posted By: philip
Date Posted: May-23-2020 at 12:25am
Thanks. I will post some pictures tomorrow. Philip
Posted By: 67 ski nat
Date Posted: May-23-2020 at 7:48am
Welcome. What year mustang. LA318 ? You probably want to cleanup and paint those mounts anyway so pulling lags does make sense , fill and retap holes same location If you remove motor every weekend, I do see a way on mine without removing lags Front mount remove large nut on top of large center bolt, Rear remove large nut under mount and pull large bolt up and out Both mount have a sideways cantilever eye bolt that lifts off those large bolts
You need to pull lags in stringers if your restoring Or removing first time check the wood under lags
Posted By: philip
Date Posted: May-24-2020 at 9:03am
66 I think trying to add a picture but I can't Figure out how
Date Posted: May-24-2020 at 9:58am
Phillip, If you are using a mobile device, it's very difficult on CCfan. The best is from a home computer or laptop. Go to "post reply" or click on the "full reply editor" (diagonal arrow above). Then click on the tree with the up arrow icon. This will bring up a browse box allowing you to select the desired off your computer. Give it a try and report back.
Posted By: philip
Date Posted: May-24-2020 at 6:32pm
Worth a try philip
