New Project
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48869
Printed Date: March-05-2025 at 10:32pm
Topic: New Project
Posted By: Smooth_swing
Subject: New Project
Date Posted: June-16-2020 at 5:46pm
Hello Correct Craft Junkies, Just purchased a heap for 1500.00 needs lots of work and Love. I am looking for any ideas as well as an outline of step to the process of redoing this boat. I see alot of potential in this vessel. 1st issue looking at the id number can seem to tell what year it is. I would like to try and restore to original look if possible.
WITH OUT FURTHER ADUE: HERE SHE IS
Early thoughts are to a finish product like this:
OPEN TO ANY COMMENTS OR IDEAS OF HOW I SHOULD PROCEED. FIRST WOULD BE TO FIND OUT THE YEAR OF THE BOAT ID SUGGESTS 1972 BUT NOT SO SURE.
Date Posted: June-16-2020 at 5:56pm
PJ, Post the HIN (hull identification number). It's molded into the hull at the upper starboard side of the transom. It will indicate the year of the hull at least.
Date Posted: June-16-2020 at 6:06pm
Looks like a 72 martinique.
Date Posted: June-16-2020 at 6:18pm
Date Posted: June-16-2020 at 6:21pm
That’s not a HIN from CC. A 72 would predate the transom HIN. I don’t see a plate near the throttle either- maybe removed when painted.
What “Boat ID” are you referencing that calls it a 72?
Date Posted: June-16-2020 at 6:27pm
This is on the back of the boat
Date Posted: June-16-2020 at 6:39pm
8122pbrainard wrote:
PJ, It's molded into the hull | Upper starboard side on the transom
Date Posted: June-16-2020 at 6:48pm
I am almost home I will look to see if I see one. Is it possible it’s not a Nautique?
Posted By: Hollywood
Date Posted: June-16-2020 at 8:07pm
Sure looks like a Correct Craft with some goofy HIN screwed on.
Date Posted: June-17-2020 at 9:10am
Probably state issued since the 72 hull would predate the transom HIN.
Posted By: Timr71
Date Posted: June-17-2020 at 1:49pm
cool project. I'll follow along. Good luck!
Posted By: ultrarunner
Date Posted: June-17-2020 at 3:24pm
TRBenj wrote:
Probably state issued since the 72 hull would predate the transom HIN. |
Yep, issued by state of Indiana.
https://uscgboating.org/content/manufacturers-identification-detail.php?id=5705" rel="nofollow - MIC/HIN code
Date Posted: June-17-2020 at 9:42pm
So obviously the engine is the first! Any insight on this old Chrysler Marine Engine? Good/bad what size it is? Having a guy come out and look at it to see if it can be salvaged.
Date Posted: June-17-2020 at 10:31pm
Smooth_swing wrote:
So obviously the engine is the first! | I'd have to say the boat comes first. Have you had a chance to check the condition of the stringers?
Posted By: Gary S
Date Posted: June-18-2020 at 12:19am
#3 https://classicmotorsports.com/articles/9-common-restoration-mistakes/" rel="nofollow - link
Posted By: zwoobah
Date Posted: June-18-2020 at 2:28pm
I agree with Pete. If you want to fiddle with the engine a bit, pull the plugs and spray some oil down the plug holes. Let it sit overnight and then try to turn the engine using a breaker bar on the crank bolt. If it turns, you should be able to get it running. I wouldn't put any more into it until you determine whether the hull is solid.
Check the stringers closely. The boat sat outdoors uncovered so it's definitely gotten wet. Tap along the stringers with a small hammer and listen for dead/rotten spots. Try tightening the engine mount lag bolts - if they spin freely, the stringers are pulp.
------------- 1968 Mustang 16 - 351W powered
