1964 aquaskier 18’ control cables
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48926
Printed Date: October-05-2024 at 3:48pm
Topic: 1964 aquaskier 18’ control cables
Posted By: Ntgast
Subject: 1964 aquaskier 18’ control cables
Date Posted: June-23-2020 at 8:59pm
Hi all, I recently purchased a 1964 aquaskier (or atomskier) 18’. It has a Chrysler 210 fury (poly 318) The control cables for throttle and shift selector are in need of replacement as they bind and appear to be in correct aftermarket cables.
Does anyone on here know what the correct cables/ cable mounting hardware would be for this boat?
Any help is much appreciated!
Nick
Date Posted: June-23-2020 at 9:06pm
Nick, Check to see if there are any ID numbers on the ends of the cables.
What makes you think they are incorrect?
Date Posted: June-23-2020 at 11:27pm
Nick, Check the ends of your existing cables. They should be threaded 10-32 https://www.go2marine.com/TFXtreme-Control-Cables-Model-CCX633-Replaces-33C-3300-Series-Cables." rel="nofollow - so I believe these are the ones you need.
Check the https://www.go2marine.com/Seastar-40-Series-Control-Cable-Pivot" rel="nofollow - pivots too since they wear though.
