Bilge Pump wiring
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48928
Printed Date: March-05-2025 at 1:17pm
Topic: Bilge Pump wiring
Posted By: illiniball2000
Subject: Bilge Pump wiring
Date Posted: June-24-2020 at 12:21am
87 Dominique Bilge Pump Auto switch light comes on above. Bilge pump Manual switch no light above Three wires off pump. One gets power with thenPump auto switch on. Other wire of same color gets no power with either switch on. Assume black is ground. Should there be a fuse somewhere no this setup? Next step t I troubleshoot? Thanks, Brian
------------- Beer is my friend 87 Dominique Had 67 Starflite
Date Posted: June-24-2020 at 8:16am
Brian, Does the pump run when it's switched to ether auto or manual? Have you checked to see if the pump is clogged with debris? Yes, the black will be ground but take a look at the other wire colors again. Both would be the same color but, one would have a "tracer" color on it typically white. Yes, there should be a fuse in there someplace.
Date Posted: June-24-2020 at 9:15am
The “switches” are breakers, there are no fuses.
Are you testing voltage at the output of the breaker or relying on the lights to determine on/off? Sounds like the manual breaker is suspect but you’ll need to start measuring.
Date Posted: June-24-2020 at 1:22pm
So I used a test light on the wires from the pump with Pump Auto/Pump Manual on and off. Never got power to one of the wires which I assume is going to the Pump Manual switch. So Does that dash slide up after taking the four screws out for access? If the breaker is bad are they available for purchase?
Date Posted: June-24-2020 at 1:58pm
You’re going to need to remove the dash panel. A multimeter will serve you better than a test light.
