Switch breakers
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49015
Printed Date: November-24-2024 at 3:15pm
Topic: Switch breakers
Posted By: ultrarunner
Subject: Switch breakers
Date Posted: July-06-2020 at 9:42pm
Hey gang, I have a nav light switch that is intermittent. Wiring looks good. are the eta switches on skidim a good replacement?
Posted By: Nauti Gator
Date Posted: July-06-2020 at 10:17pm
The ETA circuit breakers were originally installed in my '93 Sport. I just replaced all of them at the same time with new ETA's. Just check the amp rating of each because they are not all the same. Both skidim and nautique parts have them.   nautique parts lists the common amp ratings for each breaker depending on the use. I had to buy two from an electric parts house because I couldn't find the same amp rating as what I needed.
If one is going bad I would just replace them all. My boat is almost an antique!
Date Posted: July-06-2020 at 10:27pm
Mike,
Just a friendly FYI, boats aren't classified like other items like autos. The "antique" class is pre WWII. After the war boats are in the "classic" category.
Date Posted: July-06-2020 at 11:22pm
Sounds like a good fall project and swap the all out. Thanks.
Ultra.
Date Posted: July-07-2020 at 12:48am
Mike,
Thanks for the clarification - I'd rather be known as a classic than an antique
Posted By: Klundog
Date Posted: August-19-2020 at 12:57pm
Is there a source for a complete set?
I have accessory switches as well but do not know the AMP. I suppose I can remove and check them.
Related
I added a tower light and wired to the navigation switch. Shortly later, switch went bad. I suppose I should wire the tower navigation light to one of the accessory switches. Where is the best point of location to wire? seems like the switch is a hap-hazard way of doing it
Klundog
"Boats, vessels of freedom!"
Posted By: Jonny Quest
Date Posted: August-19-2020 at 10:07pm
2.5 Amp Bilge pump / auto bilge pump (8.0 Amp for Barefoot Nautique)
6.0 Amp Blower
10 Amp Nav lights / anchor lights
10 Amp Accessory
20 Amp Ignition
The above Push-to-Release / Reset breakers were on my 1994 Ski Nautique.
Posted By: Klundog
Date Posted: August-20-2020 at 12:01pm
Thank you JQ for the reply. I borrowed an accessory to get the Nav lights going
I thing I will purchase two replacement 10, a back up 20
Klundog
