Oil leak
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49044
Printed Date: March-05-2025 at 1:24pm
Topic: Oil leak
Posted By: Slalom fan 4
Subject: Oil leak
Date Posted: August-08-2020 at 7:59pm
T
Date Posted: August-08-2020 at 8:08pm
Rodney,
First understand the nut doesn't hold the prop on the shaft. It's proimary purpose is to seat the taper of the prop to the taper of the shaft.
Did you lap the new prop onto the shaft?
Proper prop installation:
https://www.correctcraftfan.com/forum/forum_posts.asp?TID=12866&KW=proper+prop&PID=145077&title=proper-prop-installation#145077" rel="nofollow - https://www.correctcraftfan.com/forum/forum_posts.asp?TID=12866&KW=proper+prop&PID=145077&title=proper-prop-installation#145077
What color is the oil? Red for trans and brown for engine.
Date Posted: August-08-2020 at 8:41pm
Only lapped without key marked then with key going to auto zone now for Prussian blue and grinding compound and new cotter pin.
Date Posted: August-08-2020 at 9:23pm
Oil is pretty fresh but looks brown on paper towel. Will need to check fresh drips. Prop must have seated pretty good because I can't get it off so will need to get puller before I can lap it.
Posted By: tryathlete
Date Posted: August-10-2020 at 1:30pm
If the prop is on there that well, just leave it on.
I bet your vibration was a completely unseated prop.
