this boat may drive me to drinking...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49194
Printed Date: November-23-2024 at 8:11am
Topic: this boat may drive me to drinking...
Posted By: uncle-buck
Subject: this boat may drive me to drinking...
Date Posted: September-06-2020 at 6:22pm
1990 Ski Nautique that I neglected and left alone for six years.
In the past five weeks, I have been paying lots of attention to her:
installed new battery
cleared fuel tank pickup tube
replaced fuel line
replaced carburetor
installed 143F PCM thermostat
reattached coaming pads
replaced water strainer gasket
replaced raw water pump impeller
replaced water pump and alternator v-belts
replaced trailer tire; balanced spare and placed it into service
applied teak cleaner and restorer to swim platform
installed Bearing Buddy bras on trailer
replaced fuel pump sight tube
replaced spark plugs
replaced distributor cap and rotor
replaced exhaust riser gaskets
changed transmission fluid
set ignition timing at 10 degrees BTDC
replaced ignition wires
replaced ignition coil
replaced exhaust manifold gaskets and bolts
checked cylinder compression
changed oil and filter; added Rislone engine treatment
installed 6.5 power valve in carb
adjusted carb floats to level
reset timing to 10 BTDC
rebuilt 1995 carburetor and installed new floats
checked distributor weights and springs
installed 1995 carburetor w 5.0 power valve
rechecked timing and advance
Took her out on the river today and she ran great for about 90 minutes. While cruising back to the marina at about 30 mph, the engine just stopped - like the throttle had been completely cut and the ignition switch turned off.
Was thinking perhaps the fuel tank pickup tube had gotten clogged so, when I got home, I disconnected the fuel line from the tank and put it into a 5 gal. can of fuel and ran it on the hose. Ran fine once the fuel pump got fuel to the carb.
Reconnected the fuel line to the tank and it ran fine there, too, for about five minutes.
Am wondering if there's debris in the tank that got sucked up into the fuel tank pickup tube and fell out during the drive home. Or if the fuel filter cartridge got clogged somehow. Or if the anti-siphon valve malfunctioned.
Any other ideas?
The boat is equipped with a Prestolite distributor and Pertronix electronic ignition conversion kit.
Thanks
Posted By: KENO
Date Posted: September-06-2020 at 7:14pm
Did you check for spark out on the river right after it quit or did you pump the throttle and see if the accelerator pump was squirting gas into the primary throats?
Don't know how long it was from when it quit till you ran it again on the hose buty ou could have an ignition system issue related to heat and after the component cools off again, you have spark again till it heats up again and quits. It could be the coil or the ignition module for example or a mismatched coil and module or an electrical connection that needs cleaning..
The Pertronix haters will now line up to tell you what they think Wink
I think I'd go for a ride with the temporary tank hooked up, the timing light in the boat so if it quits you can pretty much instantly check for spark and either rule out a spark issue or confirm one.
If it doesn't quit on the temporary tank during the ride, then you know where to look (somewhere upstream of the pump). Make sure the temporary tank is vented so the fuel pump doesn't suck a vacuum in the tank and quit pumping.
Make small circles not too far from the launch ramp to minimize any paddling that might be necessary, and go upstream Wink
Posted By: MrMcD
Date Posted: September-06-2020 at 8:27pm
How old is the fuel in your gas tank, 6 year old gas will not work.  It plugs everything up.
I am currently fixing a boat with only 2-3 year old gas that plugged up the injectors.  I did see you installed mostly the entire new fuel system but I did not see Drained the old fuel on your list.
Old fuel does usually show up slowly with a lot of sputtering, yours seemed to be an instant crash so maybe the fuel was not your issue.
Date Posted: September-06-2020 at 8:41pm
I did not check for spark or pump the throttle. Took about 90 minutes to get home. The coil is new and correctly matched with the module, according to SKIDIM. But it could have failed. Will take a spare coil next time out.
Good idea to take a temporary tank out for the next ride.
How do you check for spark using the timing light?
Thanks
Date Posted: September-06-2020 at 8:43pm
I did drain the old fuel about six weeks ago.
The fuel in the boat tank is fresh.
Thanks
Posted By: KENO
Date Posted: September-06-2020 at 8:54pm
Thanks
Just hook it up like you normally would and squeeze the trigger, push the button or whatever you have to do on yours to make the light flash.
Don't need to aim it at anything, crank the engine over and see if the light is flashing while the trigger is depressed..
It won't be flashing fast since the engine isn't running but if it's flashing while you're cranking then you have spark
No flash means no spark
Posted By: cgerdz
Date Posted: September-06-2020 at 11:50pm
Check anti-siphon valve (right where fuel line comes out of the tank), didn’t see it on your list.
Had an old MC that sat for years and it would run fine until it picked up a tiny piece of funk or plastic that stopped up the valve, and it would act exactly as you describe.
Posted By: Jonny Quest
Date Posted: September-07-2020 at 12:44am
I was out on a 1983 Ski Nautique that had a very similar engine shut down. While pulling a skier, the engine went from running just fine at 34 miles an hour to dead...it felt like someone simply hit the kill switch. We had to be towed back to the marina. The coil was pretty hot to the touch. Once the engine and coil cool down it fired right back up.  My buddy now carries a spare coil as a backup.
Date Posted: September-07-2020 at 6:34am
Wasn't on the list, but I did check it about six weeks ago and will check it again.
Date Posted: September-07-2020 at 6:41am
The coil is brand new, but could be defective.
Will test primary and secondary resistance, and begin carrying a spare.
Date Posted: September-07-2020 at 12:32pm
OK, found this on the Pertronix website. Says the issue may be caused by a voltage issue to the distributor:
Instructions for ground and voltage checks:
Did a ground check and it was perfect. Zero resistance.
Did a voltage check and got a reading of only 7.25 volts with both cold and warm engine, which is low.
What's the best way to proceed from here?
Posted By: KENO
Date Posted: September-07-2020 at 2:33pm
 I'd look at this TRB diagram and verify that you have about 12 volts at the following places
going to your ignition breaker (if you don't have 12 here, work backwards to you 8 plug connector and check the voltage at pin #5)
coming out of the ignition breaker
going to the ignition switch
coming out of the ignition switch with the key in the RUN position
and that should get you about 12 volts to the coil assuming you got rid of or bypassed the ballast resistor. It may be a little lower since you're also supplying the electric choke element and excitation to the alternator with the key in RUN.
The best check would be with the supply to the coil disconnected because if the electronic module is grounding the coil (same as having a set of points and they're closed) then you'll see low voltage like you're seeing.
Posted By: SNobsessed
Date Posted: September-07-2020 at 6:18pm
Does your distributor have a ground wire?  If not, maybe corrosion is not giving you a good ground for the EI module.
Date Posted: September-07-2020 at 11:10pm
I did the ground test described above and found zero net resistance. Isn't that indicating a good ground?
Date Posted: September-08-2020 at 5:45am
Yes
Date Posted: September-09-2020 at 12:35pm
Ken,
Followed your advice and checked voltage to/from the locations you suggested.
Have approx. 12 volts going into and coming out of the ignition breaker, into and out of the ignition switch and to the ignition coil (after disconnecting the power supply to the coil).
Also, the EI is apparently a PCM conversion module, not Pertronix.
So I'm leaning towards a diagnosis of either overheated/faulty ignition coil or a faulty EI module.
What say you?
Thanks.
P.S. Your expertise on these boats is pretty impressive.
Posted By: KENO
Date Posted: September-09-2020 at 1:08pm
Just to make sure we know which one you have, since it gets confusing, here are a couple of pictures  Wink
First one is Prestolite electronic module with the rotor removed
Second one is a Pertronix module
Date Posted: September-09-2020 at 1:44pm
It's the Prestolite shown below:
I think the replacement module would be the Pertronix Ignitor II 91589 with a Flame Thrower II coil.
But how do I know if they are needed?
BTW, I have the original distributor cam, plate, points and condenser - and could reinstall the cam and plate if a different Ignitor II kit would be better.
Posted By: MI-nick
Date Posted: September-09-2020 at 1:54pm
that photo looks familiar Wink
As far as I can tell, I'm not quite sure...
Date Posted: September-09-2020 at 4:32pm
Here are a couple of photos of the male plug on the wiring harness.
How do they look to you?
Posted By: KENO
Date Posted: September-09-2020 at 6:54pm
Hey that thing is always referred to as the 8 pin connector, but don't let anybody tell you that one pin is broken off. Wink
Pin 4 is what appears to be missing, that would be a 10 gauge Orange wire that doesn't exist on your boats "boat side" wiring harness because you have a boat with a voltmeter.
If you had an ammeter, the boat side harness would have that Orange wire running up to the ammeter.
Your engine side harness probably has all 8 wires going to it if you were to take a picture of it. That's so the same engine side harness could be used on an ammeter equipped boat or a voltmeter equipped boat.
The plugs look reasonable but you could clean them some and put some dielectric grease on before putting it back together
Posted By: KENO
Date Posted: September-09-2020 at 6:57pm
Can spot his own distributor photo..............good job Wink
Posted By: KENO
Date Posted: September-09-2020 at 7:13pm
Have you figured out yet if it's a fuel problem or an ignition problem? I'd figure that out first.
The 91589 kit you mention is as good as any other Pertronix kit.
If you were to install the original cam for the points, you'd need kit number 91582 but there's no difference in performance.
You mentioned that you have the original points stuff, now Pete's gonna get all hot and bothered and say to put them back in. Wink
You could do that and see how it runs for troubleshooting purposes.
You have to be careful that the points cam doesn't get installed 180 degrees out if you were to reinstall it. There's a little clip under that felt pad in the center of the shaft that will drive you to drinking, swearing and throwing things all at the same time. You have to get the clip off to remove the reluctor wheel and put the points cam in it's place........and then you have to get it back on all without destroying or losing the clip.
Date Posted: September-09-2020 at 9:34pm
I really don't want to wrangle with that little cam shaft clip again and am going to take a timing light and a known good ignition coil with us the next time we use the boat. If it dies again, I'll check for fuel and spark and go from there.
Right now, I'm thinking the issue was caused by a defective coil which was recently purchased. But we will see.
Thanks again for all of your help on this.
Posted By: KENO
Date Posted: September-10-2020 at 5:49am
Sounds like a reasonable plan Wink
Date Posted: September-18-2020 at 11:39pm
Haven't taken the boat back out yet, but did install a Pertronix Ignitor II EI module and a Flamethrower II coil.
The engine did not run well at all and my timing light wasn't even picking up enough spark to illuminate. Reinstalled the Prestolite EI module and it ran fine.
Now I am really perplexed.
Date Posted: September-19-2020 at 6:02am
I should have mentioned it days ago - put the point set back in. Big smile
Posted By: KENO
Date Posted: September-19-2020 at 6:45am
Here's a quote from 10 days ago Pete
BTW This would be the perfect time for you to do a tutorial on replacing your Prestolite EI module in the Tique with a set of points.
I seem to think you have all the parts necessary Wink
Posted By: KENO
Date Posted: September-19-2020 at 7:02am
Put down the bottle Buck Wink
You don't say whether you've adjusted the timing at all, but since the light doesn't light up, I doubt it.
Having installed "a few" Pertronix units, I've most always had to adjust the timing some on the Prestolite distributors.
If you make a mark down where the distributor seats on the block so you know it's original starting point, you will probably have to rotate the distributor a little at a time and see if it starts and runs any better.
I'd start by advancing it a little (turning housing clockwise).
Keep in mind that if you move the distributor 10 degrees, that gives you 20 degrees of engine timing advance, so small adjustments are better than big ones
If no luck, go back to the original marks you made and go counter clockwise.
If nothing works you at least have the marks you made to get back to the original distributor location and put the Prestolite module back in.and recheck your timing.
Date Posted: September-19-2020 at 2:43pm
Ken,
I followed your instructions on adjusting the timing and it did not run any better.
Also, following Pertronix tech support's advice, I sanded the distributor hold down bracket along with contact surfaces on the distributor and engine block to make sure the module was well grounded.
In addition, I ran a jumper wire from the + side of the battery to the + side of the ignition coil to make sure the coil was getting 12 volts. No difference.
If the Pertronix module isn't facilitating the distribution of enough energy to light up a timing light, it certainly isn't going to run the engine very well.
Am reinstalling the Prestolite EI module and coil.
If you have any other suggestions, they would be welcomed.
Thanks
Posted By: KENO
Date Posted: September-19-2020 at 7:32pm
Pass me the bottle Wink
Since the coil makes the spark and the spark is weak, maybe the coil isn't any good even though it's new. The module just tells the coil when to make the sparks
I'd probably put the Pertronix module back in and use the old coil and see what your results are spark wise.
That should tell you some good info.
I don't think I'd use the Pertronix coil with the Prestolite module though if it's the 0.6 ohm coil. It wouldn't play well with the Prestolite module.
It might be a silly question but are the positive and negative terminals on the new coil connected right.
If the wires were hooked up backwards the coil will still make some spark but not nearly the same intensity.
Date Posted: September-20-2020 at 5:22pm
Ken,
I will follow your advice and try the Pertronix module with the old coil after the weather here clears in a few days.
Am fairly certain the module was connected to the coil correctly, *but* it is possible that I made a mistake. Would be great if that's the case and all goes well when it is tested again.
Date Posted: September-22-2020 at 1:09pm
Ken -- Still raining here. Am pretty aggravated with Pertronix tech support. Opened a support ticket on their website and it was closed without a reply or solution,
Summit Racing has offered to refund the purchase prices of the Pertronix EI module and coil. Am seriously considering returning them and purchasing a DUI distributor. Any thoughts?
Posted By: KENO
Date Posted: September-22-2020 at 1:18pm
I'd probably take them up on the offer. You'll have a new distributor with no wear on it.
Jonny Quest will say it just has to be RED Wink
Posted By: MI-nick
Date Posted: September-22-2020 at 1:29pm
i'll be heading up north this weekend to install ignitor II and flame thrower II in my boat. I was feeling pretty confident they would fix my no spark issue...i still am...but, definitely not as much...
Posted By: KENO
Date Posted: September-22-2020 at 1:50pm
Don't sweat it..................Buck got the bad coil or ignitor or whatever Wink
Posted By: MI-nick
Date Posted: September-22-2020 at 1:58pm
that's what I keep telling myself Ermm
Date Posted: September-22-2020 at 1:59pm
Oh, it will definitely be RED!
Posted By: KENO
Date Posted: September-22-2020 at 5:24pm
Don't forget, you'll need some new plug wires too because of the male terminals on the cap.
Your choice of colors of course. Wink
Since quite a few people have done this swap, one of them should be able to tell you what wires fit. I made some from a universal kit so the wires would be plenty long.
Date Posted: September-22-2020 at 5:44pm
Ken -- My spark plug wires are brand new and plenty long.
I *think* I can adapt/convert the distributor ends of the wires with a boot and terminal kit for about $10.
Also, Performance Distributors recommends using a new hot wire connected to the distributor from the starter solenoid or a fuse in most applications.
Finally, Summit Racing's website indicates the RED distributor won't ship for another month, but that's OK. They are great to do business with and I want them to make some money on this.
Thanks once more for your help.
Posted By: KENO
Date Posted: September-28-2020 at 7:09am
Well at least you had good results based on your alternator/no spark thread Wink
Date Posted: October-04-2020 at 5:13pm
Put the breaker points back in, waiting for the DUI distributor to be delivered. Boat ran well. No issues. But I noticed the coil got really really hot.
Date Posted: October-04-2020 at 5:25pm
Is the coil you have exterally ballasted? If so, did you connect the coil to the low voltage side of the resistor?
Date Posted: October-04-2020 at 7:47pm
Yes, and it is connected to the ballast resistor with a purple wire.
Date Posted: October-04-2020 at 9:07pm
Bert,
Did you leave the ignition key in the on position without the engine running?
Date Posted: October-04-2020 at 9:18pm
Bert,
No, I did not and never have.
Date Posted: October-04-2020 at 9:21pm
Check the volts on the coil side of the resistor.
Posted By: KENO
Date Posted: October-05-2020 at 5:20am
Gimme that bottle again Buck Wink
Can you quantify really really hot?
It sounds like you had no running issues with the engine even with the hot coil.
Back in the first post of this thread you said you replaced the coil..........I guess I'm curious what coil you're using right now. Something like brand and part number or coil primary resistance (like maybe 1.5 ohms as an example)
And.........if you're gonna check voltage from the resistor going to the coil, do it with the engine running and warmed up to get a number that will really mean anything Wink
Posted By: peglegtoo
Date Posted: October-05-2020 at 7:47am
 On my boat the coil appeared very hot last year as well, the laser temp gauge for HF said 130 degrees. I thought that was too hot and installed a new flame thrower II epoxy filled coil.  probably overkill but it helped my hot start  issues. At the time I wondered the same question keno is asking now... how hot is hot.
Date Posted: October-05-2020 at 1:11pm
We didn't have an infrared thermometer with us. Will take one and check it next time.
The coil part no. is R117004A, purchased from Skidim for the previous setup with the Prestolite electronic ignition module. Primary resistance is 1.0 to 1.1 ohms (with engine warmed up).
Voltage is 12 volts to the resistor, and 9 volts from the resistor to the ignition coil.
That should provide 12 volts to a new D.U.I. distributor after the resistor is bypassed, correct?
Posted By: KENO
Date Posted: October-05-2020 at 7:49pm
Is that 12 and 9 volts with the engine running?
I think you should have at least 13 to the resistor with the engine running if your alternator is working as it should. And a few volts drop through the resistor
What's battery voltage when the engine is running? What's alternator output right at the output terminal
I took some "representative numbers today on a boat with points and had the numbers below with it running::
14.5 volts at the battery and also the alternator output
13.5 into the resistor
11.0 out of the resistor
coil temp of 125 ish degrees after running for quite a while. To me that's warm but not hot
These were with a 1.3 ohm resistor and a 1.5 ohm coil so 2.8 ohms total resistance.
For the DUI, I think you'd want up around that 13.5 number with the engine running and the alternator supplying power.
I'm wondering if the alternator is putting out the correct voltage.
Posted By: MrMcD
Date Posted: October-05-2020 at 9:01pm
Nice Work Ken, donated your time to offer real world numbers that should help him fix the boat.
Posted By: KENO
Date Posted: October-05-2020 at 9:58pm
it was a nice day for a cruise Wink
Not nearly as much time as you donated to your friends Cobalt
Posted By: KENO
Date Posted: October-06-2020 at 9:13am
Hey Buck
Happy birthday
Maybe you'll get one of these a little ahead of schedule today
Or one of these too
Have a good one Wink
Date Posted: October-06-2020 at 10:00am
Thank you, Ken!
I have been blessed with good health, a wonderful family, some great friends, and life in the most prosperous nation in the history of the world.
And I can still enjoy a day on the water in and behind the boat. Your continuing assistance in facilitating that enjoyment is appreciated more than you know.
Date Posted: October-06-2020 at 8:16pm
With the engine running, there were 14.3 volts indicated at the battery and the heavy orange wire on the alternator. (is that the battery positive wire?)
12 volts at the yellow wire on the alternator.
Thoughts?
Posted By: KENO
Date Posted: October-07-2020 at 8:25am
Thoughts?
Your alternator is working since the battery is at 14.3 volts with the engine running.
The heavy orange wire is the alternator output supplying charging to the battery and supplying the electrical system when the boat is running.
12 volts on the yellow wire to the alternator is low though. It should be up more in the 13.5 range.
That is the excitation to the alternator, it'll work just fine with that voltage supplied to it but.........that voltage is also going to the choke which will be just fine also and the ballast resistor supply. Your points will work OK with that 12 volts into the resistor but the upcoming DUI will be happier with more voltage like the 13.5 mentioned earlier.
It comes from the keyswitch in RUN back through pin 6 on your 8 plug connector and the wires are spliced together as shown in the photo below of that particular section of an untaped engine side wiring harness. It gets to the keyswitch through pin 5 so somewhere in that wiring you're losing too much voltage
You're losing 2.3 volts  between the battery supply and the ballast resistor supply which is a lot. Something around a1 volt loss would be much more normal and would be much better for your upcoming DUI distributor.
You previously checked that you had about 12 volts with the engine OFF and the key in RUN, but you should do the same checks now with the engine running and see where the voltage is being lost. It could be any connection in the flowpath being loose or corroded enough to affect the wires ability to carry load like where the wire connects to the keyswitch or the ignition breaker as a couple of examples
A genuine PCM wiring job
Posted By: inglesideshawn
Date Posted: November-04-2020 at 6:44pm
Your having the same exact problem I had.. Get rid of the Pertronix and put a DUI in . Just put bouth wires on the same stud so its got a solid 12volts and does not drop down for the points. seriously the best money ever spent. but just my 2c
1989 nautique
Posted By: KENO
Date Posted: November-05-2020 at 5:51am
It seems that he already bought the DUI a while back
It also seems like he vanished or something before he could put it in or update what his results were or maybe it's backordered or maybe the boat really did drive him to drinking
Buck..............you out there? Wink
