remove engine cover
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49446
Printed Date: January-16-2025 at 7:01am
Topic: remove engine cover
Posted By: tarpon32
Subject: remove engine cover
Date Posted: November-24-2020 at 10:15am
Looking at the engine cover brackets on the 1990 Nautique, what bolts need to be removed  so I can remove the engine cover? Randy
Randy
Date Posted: November-24-2020 at 10:36am
No bolts, just the 2 pins on the inside that go through the hinge, hinge bracket, and floor panel.
Posted By: tarpon32
Date Posted: November-24-2020 at 12:34pm
Thanks, getting ready to install an 80 kit, any suggestions?
Randy
Posted By: KENO
Date Posted: November-24-2020 at 1:11pm
I guess the "take it to a shop" price scared you into doing it yourself or something.Wink
Try the 3rd post from the end in the link below for a "guideline".for removing and then installing the new one.
It was for a Borg Warner 1 to 1 transmission but the basic steps are the same.
You might have 2 studs and 4 bolts holding it to the bellhousing instead of 4 studs and 2 bolts
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=42615" rel="nofollow - link
Posted By: tarpon32
Date Posted: November-24-2020 at 6:03pm
Had the kit for a year, talked to Florida Inboards, Jody couldn't take the job till New Year. Pulled the old trans and flex plate today, One man job due to room. Did the job due to now retired and acting like a bum. I will post the old trans for a give away pickup, ran fine shifted ok. didn't like the whine for long trips, had to use ear plugs. So far not running into any problems. Randy
Randy
