Barracuda strut to prop distance
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49511
Printed Date: March-04-2025 at 11:13am
Topic: Barracuda strut to prop distance
Posted By: Riley
Subject: Barracuda strut to prop distance
Date Posted: December-28-2020 at 9:41am
Does anyone have a Barracuda that has an original shaft?  I would like to know the prop to strut distance.
Posted By: Got Tiques
Date Posted: December-28-2020 at 1:16pm
Bruce, my original shaft had a strut to prop clearance of 2-3/4". I removed the shaft and coupling and had the shaft shortened and re- key wayed and resulted in about 1/2" s to p clearance. Still had adequate prop to hull clearance.
Used original stringer bolt holes to position the poly motor and tranny mounts. Runs in the upper 40's with the PO prop and no vibration. Next year will get a 1210 prop since I've replaced the distributor with a DUI and is turning lots of R's. Metrics will be provided in the spring.
http://correctcraftfan.com/diaries/details.asp?ID=4811" rel="nofollow - '78 Ski Tique
Posted By: Riley
Date Posted: December-28-2020 at 1:37pm
Todd, What is the hull to prop clearance, .75"?
Did it drive differently after you cut the shaft?
Yours is a short hull like the Classic isn't it?
Date Posted: December-29-2020 at 6:07am
Bruce,
I remember getting under Charlie's 69 Cuda when we were trying out an Acme prop. I don't remember the exact distance but was surprised how far aft of the strut the prop was. I'd say the 2&3/4" Todd mentions would be very close to what I saw.
Date Posted: December-29-2020 at 7:48am
To assist with some basic math...
Assuming a 15° strut angle, you will see a decrease in hull clearance of 27% of the amount you shorten the shaft (so shortening by 2-1/4” will reduce clearance by just over 1/2”). If it’s a steeper strut like 17°, it goes up to 30%.
Did the barracuda use the same 6wb strut as the mustang?
I have seen boats set up with minimal hull clearance (less than 1/2”) and despite the fiberglass damage that comes with prolonged use, there were no ill effects with the way the boat behaved (even the overpowered ones). While 1” or more clearance would be ideal per the general 10% rule, it seems 3/4”-7/8” is more typical, at least on mine and the others I’ve measured.
Posted By: Riley
Date Posted: December-29-2020 at 10:26am
Strut is the same, 16 degrees IIRC as we measured it.  Aligning it to the log will change that a little bit no doubt from boat to boat.  Correct Craft put longer shafts in the Cuda  than the 1st gen Mustangs with much more shaft to strut distance. We shortened ours to get the "optimum" prop to strut clearence, but that puts the prop closer to the hull and much father away from the rudder.
Based on the 3 Classics I've driven, the older short hulls drive much differently than the long hulls, although both have larger than usual strut to prop distance.
Date Posted: December-29-2020 at 12:15pm
Bruce, mine is a '66 hull and is the shorter model. And now with a tape in my hand, both the prop to strut and prop to hull are 7/8". Sorry, can't compare the before and after handling differences as I bought the boat with a cracked block and did motor and shaft concurrently.
Posted By: Hollywood
Date Posted: December-30-2020 at 4:05am
You have a Barracuda?
Posted By: Riley
Date Posted: December-30-2020 at 11:10am
Pete, sometime between now and spring, could you measure Charlies?
Date Posted: December-30-2020 at 1:58pm
No problem. I'm going over there for New Years and will make a point to get down to the boat house with a tape measure.
Posted By: Gary S
Date Posted: December-30-2020 at 2:15pm
Remember to social distance......
Posted By: 75 Tique
Date Posted: December-30-2020 at 3:30pm
Shouldnt be a problem.  COVID doesnt survive at -30* F
Date Posted: December-31-2020 at 2:04am
Neither do weak humans
Posted By: KENO
Date Posted: December-31-2020 at 5:05am
Well, through the magic of that thing called a search, here's a picture of Charlie's original shaft and Charlie too Wink
Since he got a new shaft when the old one bit the dust, there's probably not much need for Pete to measure Charlie's shaft again since it sounds like the new one was probably shorter anyways.
You can easily see the amount of shaft sticking out and get a  good idea of the length and the hull clearance since there's a ruler in the picture showing the clearance
Just trying to save Pete from having to probably lay on the ice with a flashlight on New Years Eve to get a picture of what isn't original and from the sounds of it the one in the picture may not be original anyways.(but I'll guess that it was the original)
Here's Charlie measuring the old prop. One thing to notice is the length of the prop shaft. you can see how far away from the strut the prop is. This distance should be about the same as the shaft diameter or just slightly less. When Charlie does go with a new prop, the shaft will be cut down in length. What is not known is if the shaft came from CC that way or a shaft change was made by the PO using the wrong length.
Date Posted: December-31-2020 at 5:24am
We're a step ahead of you Ken. Charlie is pulling the paper work on the new shaft  He's great on taking notes plus he and I both remember the new shaft was intentionally ordered 1" shorter than the original. He also still has the original shaft with the cutlass witness markes. Between notes, memory and the old shaft we should come up with a very good figure.
As far as laying on the ice, that's a no since he has his aerator is running so we'll drop the canoe in the slip..
Posted By: KENO
Date Posted: December-31-2020 at 5:31am
Might need a picture or 2 of this evolution
A video might be asking too much Wink
Date Posted: December-31-2020 at 10:18am
I’d wager a guess that cc’s designers were able to do the same math that I did and purposely added 2+” to the Cuda shaft overhang in order to increase prop-hull clearance by ~1/2”... and thus fit a larger (13” diam) prop. (Relative to the Mustang set up with the same strut and 12”.) Sloppy rigging for sure, but effective.
Bruce, I would compare the strut to rudder distance Cuda vs Mustang just for kicks, but even if it’s a few inches different, I wouldn’t expect that is the source of your strange handling... assuming that’s what you’re really after will all this research. I suspect a larger (heavier) than original motor, with a bit more hp, might have something to do with it. If trying to correct, I’d be shortening the shaft (like you’ve already done) and inspecting the rudder very closely for bends or other issues. I assume you’ve spoken to Reid on the topic as he’s gone through shaft and rudder issues on his similar hull/FE Classic. At a minimum I’d be running the newer style 27a rudder instead of the lillipad, but a longer (deeper) rudder like Reid uses now might not be a bad idea. I wouldn’t rule out the use of a cavitation plate back there either- the 390 Classic has a large trim tab that would also keep the rudder from ventilating, if it overhangs the transom like I know some of the 16’ boats do.
Posted By: Riley
Date Posted: December-31-2020 at 11:22am
Cudas had 12" props, but no doubt Correct Craft used longer shafts to place the prop farther from the hull and closer to the rudder for better performance.  On our 1st Barracuda back in the 70's, we had a shaft break off at the coupler.  The shaft was so long, we had it re keyed and used it, which placed the prop close to the strut.  The boat performed bad enough that we ordered a new shaft from New England Correct Craft and the problem was solved. The shorter shaft did indeed make the boat handle poorly.  The prop cavitated and the top speed was considerably less.
Our Cuda with the short shaft cavitates on left left hand corners and when riding over good size chop, something it did not do before the engine and shaft swap. I also do not think it corners as well.   I do not think the weight of the engine is an issue as the 318 poly was heavy due to all its beefy cast iron Chrysler parts and our Ford FE has aluminum oil pan, bell housing, intake and exhaust manifolds and may even be lighter than the Chrysler.   As far as it weird bow steer at medium speeds, that could be due to the combination of the wrong rudder port which needs to be recessed and the increase in prop size from 12x13 to 12x16.  However, it did not steer like that prior to the engine/shaft swap. We have the newer style rudder. Reid thinks it has something to do with the rudder port as the part of the port that is supposed to be recessed is mounted directly to the hull and is not recessed. .  For now, I want to get a longer shaft in it, maybe not as long as Correct Craft installed, but longer than what we have now. Initially, we were worried about running all that 427 power through an ARE shaft, but that is no longer a concern.
Date Posted: December-31-2020 at 11:51am
Sounds like you’ve got this all figured out. Just trying to figure out how much you’re going to lengthen the shaft I assume?
Posted By: Riley
Date Posted: December-31-2020 at 11:59am
Exactly.  I'd like to know the original spec. Once the shaft is correct, and if all characteristics go away except the funny steering, we can then work on recessing the rudder port as our fiberglass guy is all checked out to do that type of work on the Cuda.
Date Posted: January-01-2021 at 6:54am
Bruce,
Here's what's on Charlie's Cuda. The original shaft was 41".  Using the wistness marking on the old for a guide the distance between the prop and the strut was 2&1/2". The new shaft is a GP double taper and per the request, they made it 40". This gives 1&1/2" between the prop and hub. Charlie is running a 540 giving a prop to hull clearance of about 5/8".
He says there are no different handling characteristics from the original.
EDIT: Per the strut/shaft/rudder list, the shaft length is listed as 41" so, I'd say Charlie's original shaft was factory.
Posted By: Riley
Date Posted: January-01-2021 at 9:46am
Thanks, Pete.  That's good info.  The log on a Cuda must be a bit more forward than it is on a Mustang?
Date Posted: January-01-2021 at 12:28pm
Bruce,
It's been a long time since I've been in a Mustang bilge so I can't remember how close the log is to the trans. The Cuda log is real close to the point where tightening the nut on the end of a double taper shaft isn't easy. There's only about an inch between the trans and shaft coupling faces so there's no way a socket and ratchet will fit. The answer is making a special socket by cutting the length down and then welding a flat bar handle on it's end.
Date Posted: January-01-2021 at 9:43pm
A bit more forward relative to what?
Certainly not the strut of the same one was used on both boats.
Posted By: KENO
Date Posted: January-02-2021 at 6:11am
+1 ^^
Some more of that same math Wink
Same strut, same mounting angle, same distance to the log from the strut
Posted By: Riley
Date Posted: January-02-2021 at 8:07am
+1 ^^
Relative to the transom or rudder...
Date Posted: January-02-2021 at 8:56am
Those are the types of things (amongst others) that you should be checking before going down any errant paths with shaft lengthening. How many classics, Mustangs and skiers do you have to measure?
Date Posted: January-02-2021 at 11:07am
Bruce,
What exactly are you looking for? From the start of the thread, it sounds like just a shaft length?
Posted By: Riley
Date Posted: January-02-2021 at 1:32pm
Just the shaft length.  Looking for the base line as we cut ours down to "optimum" length.
Posted By: Riley
Date Posted: January-02-2021 at 1:33pm
Not enough...
Date Posted: January-02-2021 at 1:42pm
Bruce, Now I remember another reason I shortened my shaft. There was not enough shaft to rudder clearance with the original shaft to mount a 1210 prop. PO prop could be assembled, but the 1210 has way more metal nearer the center.
Yup, one more factor in the equation. Happy New Year!!
Date Posted: January-02-2021 at 1:51pm
Bruce,
That's what I thought.
I'm sure glad you aren't going down some "errant paths". Seems Timmy forgets all the times he has recommended shortening shafts so the prop runs close to the strut.
Date Posted: January-02-2021 at 6:23pm
Pete, I think your reading comprehension is really falling off these days.
Bruce is talking about adding 2+” back into his shaft length... aiming to restore the original 2.5”+ overhang (against the strong recommendation of at least one person here).
Date Posted: January-02-2021 at 6:46pm
Tim,
I know he wants to go back to the original length. How is that an "errant path". The overhung load issue?
Date Posted: January-02-2021 at 6:57pm
Because every tidbit of reliable information on the subject, combined with a pretty reasonable amount of personal experience (especially in overpowered boats) says that minimizing that dimension is optimal from a reliability and performance perspective.
Date Posted: January-02-2021 at 7:27pm
In your experience what exactly happens without minimization? "reliability and performance perspective" is pretty vague.
Posted By: KENO
Date Posted: January-02-2021 at 8:24pm
Pete, It must have something to do with this "overhung load" you speak of when your shaft is too long. From a thread sometime in the past
Originally posted by Dieseldawg Dieseldawg wrote:
I have to ask, what will be the benefit of shortening the prop shaft?
The less shaft length you have hanging out past the end of the strut, the less stress will be put on the shaft.
And the cutlass bearing.
Matt,
As a mechanic, you should know this. In mechanical engineering terms, it's called "overhung load"!    A basic principle of physics and the use of a lever.
Date Posted: January-02-2021 at 8:36pm
We don’t need my testimonial- but I think it’s relevant to hear Bruce’s theory on how reducing that shaft to prop dimension caused problems.
Based on my reading and experience I think it’s highly likely there is something else going on- maybe it was induced by shortening the shaft or maybe it’s another rigging or set up issue, possibly related to the installation of a significantly heavier, more powerful engine.
Date Posted: January-03-2021 at 6:41am
The overhung load is a given but what are the performance problems?  Besides the cavitation Bruce,what other, handling issues are there? Tim?
Posted By: Riley
Date Posted: January-03-2021 at 8:53am
I simply want the original spec to use for a base line.  How much length gets added to the shaft will depend on moving the shaft into different places and making a decision.
There are 2 things to consider, prop to strut clearance which affects shaft performance, and prop to hull clearance which affects boat performance.  I don't see how anyone can disagree that shaft performance is secondary to boat performance. If perfect shaft performance is causing poor boat performance, what good is the perfect shaft performance?
In the case of the Cuda, Correct Craft put long shafts on them for a reason. While some people might cringe at the sight of their excessive prop to strut distance, they perform well and have been running like this since the 1960's.  In our case, we went with a short shaft in order to have perfect shaft performance as we were installing an engine that had 300 hp, much more than what was in the boat originally, and we knew it would require more prop, which it did.  We went from 12x13 to 12x16.
I've explained the handling characteristics on page one.  Based on my experience with 2 Cudas, I believe lengthening the shaft will be an improvement and make the boat handle better as it did with the longer shaft.  I'd rather not go to 2.5", but certainly .5" is inferior as far as boat performance goes to the original spec of 2.5".
As far as weight of the engine, I cannot find an Interceptor spec that has the weight of the FE marine engine.  I did find automotive specs that have the 318 at 550# and the 427 at 650#.  Chrysler Marine states that the 318 was 750# with all their beefy marine parts on it.  Given all of the light aluminum parts that the Interceptor has, I'd bet the 2 marine engines weigh about the same and the Interceptor maybe slightly lighter.
This isn't rocket science and I often think some of us are overly critical of some of the things Correct Craft did in building their boats.  The long shaft on the Cuda may have been an unorthodox fix to enhance boat performance, but it worked.
I simply want the original spec so that we have a base line.
Date Posted: January-03-2021 at 10:05am
Thanks Bruce,
Keep us informed how it works out.
Posted By: KENO
Date Posted: January-03-2021 at 10:18am
Bruce
It sounds and looks like you have the original spec between the picture of Charlie and the measurement numbers from Charlie by way of Pete
What I wonder about is your comment on the rudder port that is not mounted flush but sticks down from the bottom of the hull.
Was that bigger rudder and new port on there before the problem started or was it put on to try and solve the handling issue?
You mentioned Reid thinking that might be the problem, you can add me to that list.
Is it hanging down say 1/4 inch or so with squared off edges or is it tapered so it's at least somewhat hydrodynamically efficient
If you recess it like it was originally built, you'll be back to "baseline" there too
Posted By: Riley
Date Posted: January-03-2021 at 10:30am
The rudder port is an issue and will be recessed.  It did not cause any problems prior to the engine swap, however.  The problems I noted on page one I know to be from the shortened shaft as I've experienced them with another Cuda.    I tried to install an original rudder port, but the hull has been altered to except the newer style port.  This was done by a PO.
Posted By: KENO
Date Posted: January-03-2021 at 10:42am
Sounds like longer shaft time.
Plenty of CC's had a lot of strut to prop clearance over the years.
Gen 2 SN's and the Martiniques on that same hull come to mind with over 2 inches of distance.
You have the info you wanted, you know the boat, I'd go with what you think needs to be done right now Wink
Posted By: KENO
Date Posted: January-03-2021 at 11:20am
Not to throw a curve ball at you Bruce, but if you look closely at your strut and Charlie's strut they're not the same so any measurements from his may not really be what you're looking for if you're trying to get the prop location in it's original spot.
If you took an inch or so off of Charlie's, it would look like yours
[/QUOTE]
Date Posted: January-03-2021 at 11:50am
Bruce,
Yes, the struts are different. Looks like you have a 6A and Charlie's is a 6A6. The 6A6 is 1 inch longer at the aft end so, that really puts the prop farther aft. I'd say the aft move was due to CC going to a 13" prop.
Posted By: KENO
Date Posted: January-03-2021 at 1:19pm
Bruce,
Further aft of what?
They're both 17 ft Barracudas, assuming the transmissions are mounted in the same spot and the struts are in the same spot and you put a 41 inch shaft for example in both, the prop is in the same spot on both boats.
On the boat with a 6A6 it sits closer to the strut by an inch though since the difference in the struts is all at the back. Trim an inch off the back of a 6A6 and it's the same as a 6A
I guess you'll have to explain how that gives any more room for a bigger prop Pete Wink
Date Posted: January-03-2021 at 2:01pm
Sorry but I'm not a math teacher
Posted By: Riley
Date Posted: January-03-2021 at 2:59pm
All things being equal, Charlies strut would allow for less prop to shaft distance as the strut reaches farther aft.
Anyway, I appreciate the info and welcome any more measurements I can dig out.  Our original shaft was bent pretty badly, but maybe I can dig it out if it didn't go to the scrap pile.
Posted By: KENO
Date Posted: January-03-2021 at 3:15pm
Pretty poor attempt at avoiding the question Pete Wink
