Another project I’m still working on is a reverse observer
seat. My boat originally came with a bucket seat up front. So I always
wanted the reverse observer seat from day one. After a very long time locating one, this one I purchase will
need a lot of TLC to the plastic base and the seats plywood rebuilt/replace. So
I started doing some research on what type of black plastics are wieldable and how
to repair since I never done this before. The seat base is a type
of polypropylene. A thermoplastic that I should be able to weld back together.
The seat base I brought has really damage and abused. It had
3 major breaks and 13 stress cracks
The break along the back where you can see the foam, I cut some
of that foam out in order to pull it back together. Was not a whole lot but
enough so when I start clamping, there won’t be any resistance. I clamp the
base up and heated up the seat base with a heat gun to formed back in shape
again. I reheated the base every other day for 2 weeks. After forming back into the original shape, I used some Gorilla
Glue that is compliable with the foam inside the base to glue the foam back
together that I cut out. And then re-clamped all back up.
Went to Harbor Freight and purchase a plastic welder kit. Kit comes
with everything you need for the repairs. I did a small practice spot on the
bottom of the base to see if it’s wieldable. And yes it is.
Removed one clamp to have access to the back support of the
base where you could see the foam and the long crack. Welded the crack all away
across. Just enough plastic rod to weld back together. The kit also came the wire screen. Cut to size and I reheated the area while I push the
screen into the plastic on both side of the crack for re-enforcement. Added
more welder plastic rod on top of the screen for more strength. Made sure I
heated the original plastic along with the new welding rod plastic to blend
together.
As I continue welding the base back together I got better
welding and went quicker. The trick is to blend /weld the plastic back together
to have a good connection again. All of this was slow work.
This is the back side of the base where I screened in
after I welded the crack. Also the front of the base needed screen. After the
screen was tack in place, I went back over to push it in deeper into the plastic
so that it’s below the surface level. After all the breaks and cracks where all welded back
together, Only 3 areas where screened in for reinforcement. The other cracks
were just welded back together. All areas were sanded smooth. Many steps in the
sanding process. By all means this base is not perfect but I was able to salvage
a part from ’88 and repaired it for my Nautique when I get the seats rebuilt and
recovered. Looking forward when all is completed and installed.
