Circulation Water Pump - 84SN2001
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49729
Printed Date: November-23-2024 at 5:43am
Topic: Circulation Water Pump - 84SN2001
Posted By: OldSchoolBlue84
Subject: Circulation Water Pump - 84SN2001
Date Posted: April-07-2021 at 10:35pm
Hi everyone, I’m in the process of changing out the circulation water pump on my 84 SN 2001 and have a question. Within the description of the new pump it states “older pumps do not use the two additional newer style mounting holes (not used) so just ignore them for the older applications.” Would those holes happen to be #8 and #9 in green below? If so, I’m assuming the gaskets provided with the pump would prevent any leaks to bolt holes #8 and #9? Bolt holes #1 through #7 in red would be the holes I’ll be using to mount to the block. Want to make sure before I install tomorrow. Thanks in advance!
https://ibb.co/MBWKJRt" rel="nofollow">
https://imgbb.com/" rel="nofollow - upload pic
https://ibb.co/0n46mZx" rel="nofollow">
Kostas
http://www.correctcraftfan.com/diaries/details.asp?ID=6700&sort=&pagenum=1" rel="nofollow - 1984 Ski Nautique 2001
Posted By: KENO
Date Posted: April-08-2021 at 5:15am
Makes sense to me
You should send your pictures to SkiDim so they could use them to make a good, easily understood description Wink
Date Posted: April-08-2021 at 9:00am
Thanks Ken
Kostas
Posted By: KENO
Date Posted: April-08-2021 at 4:44pm
Here's a picture of a Ford marine timing cover with a couple of pointy things sticking out of the holes that line up with those 2 extra holes in the newer water pump.
They may be holes but they're shallow, unthreaded and go absolutely nowhere. Wink
Date Posted: April-08-2021 at 11:18pm
Thanks Ken, well all done. I guess she’s been leaking for awhile 🥴
https://ibb.co/dm2zDZB" rel="nofollow">
https://ibb.co/qR5wHzy" rel="nofollow">
Kostas
