I've been searching through existing posts on this topic, and will continue to do so since this is a well discussed topic.
I got my 78 mustang 17' out of storage and spent last Saturday am getting de-winterized. At about 1pm, I was ready to fire it up and within a few tries she was running fine. Ran for about 15-20 minutes, everything was looking GOOD. I shut her down for a few minutes and started again to double-check. This time, I notice that water is no longer coming out in the exhaust. Temp gauge gets up to ~160, so I shut her down.
[1] first attempt, ran fine and temp gauge reading close to 140. [2] second attempt, overheating - no water in exhaust. Quite surprising that I went from all good to overheating within a few minutes without changing anything ???
I have my water intake set up to suck water from a trash can (thru a short hose). Hose is clear, no problem there. - I was thinking to check for suction at the end of the hose; should I feel a constant suction or only when thermostat opens?
Checked the impeller, looks fine (probably 2-3 years old). Thought maybe the thermostat got stuck (seems unlikely since it was fine a few minutes prior). Had a spare, so I changed out the thermostat. Now, I'm getting a water leak at the thermostat housing. So, I feel like there is water and water pressure at the thermostat. After a bit of playing (gasket, gasket seal, let it dry), try again today.
No water leak, but temp gauge gets up to 160, So I shut her down. No water in the hose connected into the thermostat housing.
Ideas to try next: [a] run without thermostat, to eliminate any potential issue there. I expect to see water out the exhaust right away. check for air leak in any of the hoses; I see that this is discussed as a likely cause for overheating problems. Not sure how to identify issue here, unless I see cracks? Other ways [c] check for blockage in the trans cooler; I will be able to inspect that visually. [d] run water directly from garden hose into RWP (instead of letting pump suck it from task can). I though I had heard this was not recommended....
In terms of checking for blockage, is there any reason not to do the following: [a] disconnect hose from RWP intake, use garden hose to spray water into this hose to see if there is any block between this point and the water intake? In other words, run water through the system in the counter direction.
Thanks and regards - Gary
