1998 Air Nautique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=49866
Printed Date: March-04-2025 at 5:28am
Topic: 1998 Air Nautique
Posted By: baysport22
Subject: 1998 Air Nautique
Date Posted: June-04-2021 at 9:36pm
Recently bought a 98 air Nautique not running.
I need to know what rotation it is and what distributor belongs in it because there was two different ones laying on the boat.
The motor is a carbureted 351.
Any help or suggestions would be much appreciated.
Posted By: KENO
Date Posted: June-04-2021 at 9:50pm
If you're saying that you have a distributor with a Reverse rotation gear and another with a normal rotation gear, only one will fit  in and mesh with the cam gear.
Normal rotation, the distributor gear teeth go like this //////
Reverse rotation looks like this  \\\\\\\
I'd start with the normal rotation setup and it should fit Wink
If you're saying something else, then you'll have to explain things better
