snapped my rudder :(
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=50067
Printed Date: March-04-2025 at 1:50am
Topic: snapped my rudder :(
Posted By: jblocal
Subject: snapped my rudder :(
Date Posted: July-26-2021 at 6:13pm
Came in from fishing this weekend and broke my rudder off backing into my friends driveway. Ouch Does anyone happen to have a 1 1/2" shaft rudder for a Fishnautique laying around or know where I can find one?
Posted By: Gary S
Date Posted: July-26-2021 at 8:02pm
Don't know who would but Buck Algonquin was the supplier to CC. The master list shows a 11A was used as you can see here alot of models used them.
Posted By: KENO
Date Posted: July-26-2021 at 9:05pm
That doesn't look like an 11A rudder (slightly different shape) and an 11A doesn't have a 1/1/2 inch shaft either
Are you sure you have a 1 1/2 inch shaft?
Maybe it's been changed at some point in the past.
It does have the square top of the shaft for a CC style tiller arm though.
Posted By: jblocal
Date Posted: July-27-2021 at 7:59am
It’s not a 11a and it is 1 1/2” shaft. My fish is a 87 so maybe they change rudder in later years or was replaced before I got the boat. I have found similar sizes but all the shafts are 20” so looks like I would need to have it cut to 7” and have the square machined for tiller arm.
Posted By: gun-driver
Date Posted: July-27-2021 at 8:00am
Didn't Jeff over on PN have a couple Fish Nautiques when he was restoring his, maybe he has one laying around.
Posted By: KENO
Date Posted: July-27-2021 at 8:19am
There are an old thread or 2 here on CCF referencing the same 1/1/2 inch shaft. on a big FN (they had no resolution to their problem though).
Here's a link to a Marine Hardware catalog where you may or may not find a solution, without getting a new tiller arm also, or making a special order or something like that.
If nothing else there's plenty of good reading and info Wink
http://www.marinehardware.com/downloads/running_gear.pdf" rel="nofollow - link
Date Posted: July-27-2021 at 8:46am
The shafts come untrimmed so they can be used in several different ports. We would get a new rudder in, cut it to length and cut the square top. All plain hack saw work. Drilling and tapping the top for the safety bolt was even done with a hand drill.
Posted By: 67 ski nat
Date Posted: July-27-2021 at 9:03am
Posted By: jblocal
Date Posted: August-15-2021 at 8:04pm
Ended up having my local prop guy make a stainless match. Seems I got lucky and he had a similar one laying around from a canceled order and modified it to match mine. A new one from BA is crazy expensive  Ran the boat today can't tell a difference from old one.
