Since that's a clip down cap earlier Prestolite as compared to the screw down cap version used from 87 on, PCM's number for initial timing was 6 degrees BTDC.
The later one was 10 degrees because the advance limiter plate was different.(it's the slotted thing with the point cam attached in the picture below)
I'd look under the points plate and verify that the weights move freely and aren't all rusted up and also verify that both advance springs are intact.
The 2 springs are different from each other.
One is heavy with oval shaped ends and has no tension on it when just sitting there. It only works to limit advance at high RPM like above about 3500.
The small one with lighter wire should have tension on it while just sitting there and is working through the whole RPM range.
Since it works a lot harder than the big one, it can break or stretch too much and wreak havoc on you ability to get the timing right.
Here's a picture showing both springs installed at rest
Heavy spring is top left and lighter spring bottom right
If you have spring issues, you'll have curve issues ![Wink Wink](smileys/smiley2.gif)
here's a "typical" curve for the clip down cap distributor with good springs and weights.( and no wear or slop, but after 39 years there's gonna be some)
RPM Timing
500 O + initial timing
1000 4 + initial timing
1500 12 + initial timing
2000 16 + initial timing
2500 18 + initial timing
3000 22 + initial timing
3500 24 + initial timing
4000 24 + initial timing
So you could set it at 6 degrees and come up with about 30 degrees at full throttle or set it at 10 degrees and get about 34 degrees
Here's a link to a PCM manual from the 80's (from the CCF reference section) that should be helpful to you. Page 8 has idle speed and timing info.
http://www.correctcraftfan.com/downloads/PCM_Owners_Manual_Ford_and_Chevy.pdf" rel="nofollow - link
