76 Nautique weight
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=50239
Printed Date: March-04-2025 at 1:00am
Topic: 76 Nautique weight
Posted By: jimrogers74
Subject: 76 Nautique weight
Date Posted: September-19-2021 at 10:29am
Does anyone know the actual weight of a 76 SN? I’m admiring a used Floe lift if it’s strong enough to hoist mine. (With a couple people, fuel and some equipment)
Thanks much.
jimrogers74
Posted By: gun-driver
Date Posted: September-19-2021 at 11:15am
Looking at the remaining brochures a ‘ 74 weighs 2100 lbs and an ‘80 weighs 2100lbs, so I would guess that you could that number for yours and be in the ballpark.
Date Posted: September-19-2021 at 11:31am
brilliant! thanks sir.
jimrogers74
Posted By: Donald80SN
Date Posted: September-20-2021 at 1:46pm
Please remember you could have 100's of extra pounds of wet foam in the boat since it is a 76 model. I would add a few hundred.
FYI,
Donald
1968 Ski Nautique, Project.
Posted By: ultrarunner
Date Posted: September-20-2021 at 4:18pm
Jim, you need at a minimum a 2500 lb lift when you factor in fuel and gear, as you mentioned…3000 if you’re going to hoist with people on board. This isn’t factoring the possibility of the wet foam that Gun mentioned. If you’re hoisting using a lift at its limit, you’ll go through cables.
Posted By: burban65
Date Posted: September-20-2021 at 6:18pm
This chart has helped me out many times over the years.  Not sure where I acquired it.......most likely from the site.
SRB
Date Posted: September-20-2021 at 7:40pm
fair enough.
the cool thing is the foam in the belly is bone dry....I just had stringers /floor / paint done last winter, and working on motor rebuild now. even had the trailer restored.
guys, this boat is going to be stunningly beautiful! I can't wait until I get it on the water---presumably next summer.
appreciate the replies. I'm afraid w/ a dude or two in it I might be taxing this lift.
jimrogers74
Date Posted: September-21-2021 at 9:41pm
Can’t you get the people out of the boat before you raise it ?
Date Posted: September-22-2021 at 7:46am
3k would get the job done but I wouldn’t go any lighter than that. 3500-4k lb lifts will do the job more comfortably and have a bit more margin and/or room for growth.
Date Posted: September-22-2021 at 11:32am
Certainly!
jimrogers74
