crankcase breathers
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5065
Printed Date: November-27-2024 at 1:49pm
Topic: crankcase breathers
Posted By: bmiller
Subject: crankcase breathers
Date Posted: October-25-2006 at 8:53am
Hey guys need some suggestions,I am detailing the 302 in my 1978 mustang.New billet valve covers and painting the engine,you know just a very clean detail job.One question is that I'm thinking about replacing the pcv valve with a crankcase breather.Will I have a problem with this in terms of the fumes being introduced in the enginge compartment or should I just stay with the pcv valve?Is anyone else out here useing crankcase breathers?Is this a safe thing to do?Any feedback would be great.
Posted By: 79nautique
Date Posted: October-25-2006 at 10:54am
you cannot relpace the PCV with a breather they are not the same and do not perform the same function. You should have a breather on one and a PCV on the other valve cover.
Posted By: bmiller
Date Posted: October-25-2006 at 11:34am
Thanks 79.I was just curious about the situation.
Posted By: David F
Date Posted: October-25-2006 at 11:57am
Chris:
Question: Couldn't you use two breathers and be ok? Seems I have seen setups like this on the older boats.
They way I see it, the breather works at high vacuum conditions (i.e. idle and small throttle applications). The PCV comes into play at large throttle applications to help evacuate the crankcase during periods of maximum blowby or crankcase pressurization.
I do tend to think that one breather could get overwhelmed (especially on older engine) with the result of excessive pressurization of the crankcase.
Just my thoughts.
Date Posted: October-25-2006 at 12:25pm
PCV is to remove moisture from the engine and operates under vaccum, the breather is just a vent and requires no vaccum. Some engines have the PCV mounted else where or remove the moister by a different means thus the extra breather
Posted By: 75 Tique
Date Posted: October-25-2006 at 12:34pm
Brian,
I asked the same question a few weeks ago for the same reason. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=4859&PN=2 - similar thread(with pictures)
Some speculated there must be a pcv valve within one or both of the fittings for the hoses from the covers. They were both just breathers. My boat (76 chevy 305)did not appear to have any pcv valve. I know there are external pcv valves but I don't have one. So as to not take any chances on mucking things up, I found valve covers with the same hole configuration as my orginals. Post before and after pictures of the engine face lift. Curious to compare since we are both using the fall to tinker with our boats in the same way.
Posted By: bmiller
Date Posted: October-25-2006 at 12:49pm
Well I have a closed emission system so my filler cap has the hose going to the flame arrestor.I still need to stay with a push in oil filler cap with the tube so that I can run that hose to the arrestor.The problem was finding the correct grommets for the valve covers so that the pcv valve would work.I have found the right ones but I was just curious to see if I could use the breather.Thanks guys.
Posted By: boat dr
Date Posted: October-25-2006 at 8:44pm
bmiller you can run either type, all the mercruisers have used a breather type ,hoses vented to the flame arrester, for years, contrare to 79,pcv, positive crankcase ventalation,is to remove the hydrocarbons that would have been vented to the atmospere. this was the first of emmision control devices.as a secondary result of this "sucking action" you got less "weeping" or "blowby" from the valve covers and dipstick.if you have a motor with a lot of hours leave the PVC system intact, a new engine or low hour will do just fine with twin breather tubes(mercruiser still uses this).my new 331 stroker has no blowby and uses the two hose system,go to my link and i think you can see how i did mine....... boat dr
and as far as removing moisture from the motor,my quetion to 79 would be where did it come from,and i dont have this problem.
boat dr
Date Posted: October-26-2006 at 9:28am
the moisture comes from condensation that builds up in the motor.
Date Posted: October-26-2006 at 10:07am
The condensation is a result of the combustion process. Water (very small amounts) is a byproduct of burning gasoline.
Posted By: Tim D
Date Posted: October-26-2006 at 1:02pm
I think 79 is refering condensation inside the block from heating and cooling.
Tim D
Date Posted: October-26-2006 at 3:04pm
that would be hydrocarbons
or unburnt gasoline during the combustion process,
if there was water present it would instantly turn to steam and be pumped out the exhaust.
Posted By: 65 'cuda
Date Posted: October-26-2006 at 5:02pm
Quite a lot of water is a by product of burning gasoline, or any hydrocarbon. In a perfect reaction nearly one gallon of water is produced for every gallon of gas burned. Of course, nearly all of it leaves in the exhaust as water vapor.
Gary
http://www.correctcraftfan.com/diaries/details.asp?ID=941" rel="nofollow - 1965 Barracuda SS
Posted By: David F
Date Posted: October-27-2006 at 12:38pm
Oh crude, I disagree with Brian again. The moisture in the engine will get out simply by evaporation via a crankcase breather. Here is blurb on the PCV valve:
Description: The crankcase ventilation system, often called positive crankcase ventilation (PCV), consists of a PCV valve or metered orifice (calibrated opening), its vacuum hose or line, a supply hose providing air into the crankcase, and on some applications, a breather filter to clean the air provided to the supply hose.
Purpose: The purpose of the PCV valve is to regulate the flow of crankcase fumes into the intake manifold where they can be burned. Prior to 1963, cars had no PCV and used road draft tubes that just left the hydrocarbon emissions from the crankcase out into the open air. The PCV valve also has a secondary role as a check valve, to prevent flow back into the crankcase. This prevents potential ignition of the crankcase fumes, should the engine backfire. The PCV system is also crucial for to proper engine sealing. The system alleviates crankcase pressure, which can push out on seals and gaskets, contributing to oil leaks.
Here is a good PDF describing the PCV system:
http://www.filtercouncil.org/techdata/tsbs/94-2R1.pdf - Crankcase ventilation
