I went out with some old friends yesterday to ski. 4 in the boat, ages 64 to 76. We all took 2 ski runs each. Most amazing the 76 year old had a knee replaced in April and has resumed water skiing and looked great out there. We did not use my Nautique this time. We were in a 1986 Mastercraft one of the other guys owns.
After every ski run the boat would not want to start, ran great, pulls hard, has the Powerslot tranny.
Asking him questions trying to help, no tools in his boat. It does have some kind of electronic Points replacement, Petronix? I did not look to see what type. His coil was no hotter than the manifold below it. It did not seem to matter if we pumped the gas or not. He said last time it did this he checked the plug wires, said when it has no spark it won't start and then suddenly it has spark again and starts.
Trying to figure out where the issue is. His ballast resistor is removed. Seems to have 12V at the coil. Again, no tools so could not do much. He has replaced the key switch and mentioned it does have one extra pole that is only hot while the starter is engaged. Is this pole supposed to be hooked to a second wire that goes to the positive side of the coil?
I think the second wire would trigger the starter solenoid and then go to the Coil to provide 12V while cranking? The boat cranks perfect when the key is turned so something is off it does not always start. Starts perfectly cold but no start after a ski run. Sometimes it does not start for 30 seconds, sometimes 5-10 minutes, then fires up and runs like brand new? When it starts, it starts like there was never a problem and instantly goes into a normal smooth idle and runs fine to ski. You do not have to rev it to clear our fuel, it just starts and purrs.
I will try and help him fix it, just want to see if my thoughts are accurate as to the cause. I think this is a PCM engine, it looks like the standard 351 PCM but I did not really check. Manifolds etc looked just like my 78 Nautique PCM. I have the PCM wire harness diagram and Tim's nice diagram but I keep thinking about the one pole in the ignition switch without a wire attached that is only hot while the starter is cranking. Makes me wonder what is triggering the starter to turn, I have not seen a switch with 2 start poles on the back of the switch. Again, this information came from the owner, it needs to be verified. the boat ran fine for a season after the new switch was installed and then started acting up, according to the owner. This was my first ride in this boat so no history to share from me but the owners brother is a good friend and he told me the starting issue has gone on for a while now. Ski report, wake was nothing special, low but a little hard, boat tracked good. Water was perfect and flat for us so I did not get to enjoy the flat bottom Mastercraft thump on wakes. They all skied on 75 foot rope so I did that also. Have not done that in a while. Turns felt slow but it made you think about body position in the whole turn and pull. In short line it all happens much faster not much time to think.
Thanks
