thermostat
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=51216
Printed Date: November-21-2024 at 7:47pm
Topic: thermostat
Posted By: BaccoBouncer
Subject: thermostat
Date Posted: June-27-2023 at 2:59pm
I have a '97 Sport Nautique with the Chevy 350 PCM engine.  I need to replace the thermostat but I think what is in there is not correct.  My questions are.  What gasket is needed internally, o-ring, cork, etc?  Does this gasket go in first and then the thermostat and then the plastic collar/spacer.  What gasket do I need for the manifold attachment to the block? Which side of the thermostat should I see after I assemble it into the manifold?  Thanks
'97 21' Sport Nautique
Posted By: pjsmoreno
Date Posted: June-27-2023 at 4:09pm
I know you said your engine is a 350 Chevy. That thermostat housing is the same as my 454 Chevy is but the thermostat itself is way different then your setup is. Are you having problems with the engine not warming up to correct temperature?
The gasket is the standard Felpro thermostat gasket for a small block Chevy. there should be a lip around the housing for the thermostat to fit into and then the gasket goes on.
The thermostat I used on my engine is much larger and it fits up inside the thermostat housing. And I hate to say it but the thermostat from SkiDim is $111.50, Item #: RP026003.
When the engine reaches operating temperature, the thermostat opens up into the housing to let the warm water out into the exhaust risers. I believe that’s how it works.
Date Posted: June-27-2023 at 4:16pm
The thermostat silver metal goes up into the thermostat housing and the dark area where the spring is goes into the intake manifold,
Paul
Posted By: KENO
Date Posted: June-27-2023 at 4:37pm
If you click on the link below and go to page C4-1 and C4-2 you'll find your thermostat housing for 97 and later PCM engines
http://www.correctcraftfan.com/downloads/1998_PCM_Parts_Manual.pdf" rel="nofollow - link
It takes an automotive style thermostat like yours.
It also shows the earlier one that took the big, tall, expensive one.
The exploded view shows how it goes together
Pointy side towards the sky Wink
It's not like Paul's
Date Posted: June-27-2023 at 4:54pm
Oh Wow,  That's perfect.  THANKS!
I see this thermostat shows as a 160 degree when I look it up online (not 143).  Does this matter or is 143 required?
Date Posted: June-27-2023 at 6:50pm
Is the manifold sealing surface to the thermostat broken or is this section supposed to be missing?
Date Posted: June-27-2023 at 7:08pm
If so, is this an appropriate replacement: Mercruiser 860256A4
https://marineenginedepot.com/thermostat-housing-43l-57l-raw-water-cooling-system
Posted By: KENO
Date Posted: June-27-2023 at 7:27pm
That's how it's built
It's one of the flow paths through the housing.
The retaining adapter (part #6 in the manual) goes in with it's opening lined up with that opening.
The adapter only fits one way, there's a ridge that lines up with the groove at about the 1 o'clock position in your picture.
As far as the thermostat, it won't hurt to try the 160, you may like it . If it runs a little warmer than you're comfortable with, get a 143.
Date Posted: June-28-2023 at 7:12am
Sorry for the miss information. Thanks Keno!
Date Posted: June-28-2023 at 9:20am
This is what it looks like with the adapter in
Date Posted: June-28-2023 at 9:25am
With the thermostat is I can see past the edge of it to the bottom of the manifold.
Date Posted: June-28-2023 at 9:26am
SKIDIM has this.  https://skidim.com/housing-t-stat-indmar-gm.html
Posted By: KENO
Date Posted: June-28-2023 at 11:57am
I still say that's the way it should be. A little bypass flow while the engine is warming up
Since you're thinking about a new thermostat housing, I'd at least try using what you have now.
You might like it Wink
Date Posted: June-28-2023 at 8:15pm
ok thanks
Date Posted: June-25-2024 at 7:41pm
I piut a new dash gauge in but  found the temp didn't check out.  I put a hot mug of water on the deck and put the sender in it. and a liquid thermometer.  The thermometer gave me 180 when the dash  gave me 150  This tracked with a thermometer of 165 and a dash reading of 135.  I did an ohm reading and it seems that actual water temp at 113F is an ohm reading of 334 and a water tempo of 167 is ohm 205.(() => { window.addoncropExtensions = window.addoncropExtensions || []; window.addoncropExtensions.push({ mode: 'emulator', emulator: 'Foxified', extension: { id: 44, name: 'YouTube Downloader by Addoncrop', version: '17.2.9', date: 'March 31, 2024', }, flixmateConnected: false, }); })();
So I want to put in a new temp sensor as the next step.  I just want to make sure I pick on with the correct ohm range.  My boat is the Chevy 350 based PCM.  What do I search for?
Date Posted: June-25-2024 at 7:47pm
This is the gauge i put in
Sierra International 65509P Lido 120 to 240 Degrees F Dial Range Scratch Resistant Water Temperature Gauge, 2"
So I need a sensor that matches it
Posted By: KENO
Date Posted: June-26-2024 at 1:25pm
The marine senders for single gauge helms are a standard sensor so yours should be compatible with the new gauge but here are a few part numbers for Sierra senders that will work depending on the size of the hole you're screwing it into.
TS 26611 for 1/4 inch pipe threads
TS 26621 for 3/8 inch pipe threads
TS 26631 for 1/2 inch pipe threads
