12volts plus at battery getting 10volts at coil
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=51320
Printed Date: December-02-2024 at 2:08pm
Topic: 12volts plus at battery getting 10volts at coil
Posted By: Jtibbet
Subject: 12volts plus at battery getting 10volts at coil
Date Posted: August-21-2023 at 11:45am
Any suggestions?
New starter
New Alternator
New key switch
New breaker
I take key switch wire off I get 12 volts put it back on I’m at 10 volts
I take coil wire off test it I’m at 12volts put it back on I’m at 10 volts
Please help for any suggestions
It’s in a 1993 Ski Nautique
James
Posted By: KENO
Date Posted: August-21-2023 at 1:08pm
What do you have for an ignition system?
Maybe breaker points with a ballast resistor
Maybe electronic with no ballast resistor or some kept the resistor.
If you have a ballast resistor those readings are pretty normal.
Are you having starting/running issues or just being curious? Wink
