Whoops... transmission question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5153
Printed Date: November-18-2024 at 3:32pm
Topic: Whoops... transmission question
Subject: Whoops... transmission question
Date Posted: November-05-2006 at 11:44am
Hopefully our transmission experts (Eric???) can help me out here. While attempting to drain my transmission fluid today, I accidentally fed the tube of the hand pump into the wrong hole in the dipstick. Instead of going straight down into the hole, the tube curled right (towards the stern) and into the compartment pictured.
I realized my mistake when I wasnt sucking any fluid. When trying to take the hose back out, it got snagged on something. Despite careful ma$$aging, I could not get it unstuck. A stong pull caused the tube to break inside the tranny. I am not sure how much hose is in there, but it could be several inches.
What options do I have now?
Posted By: Randy_in_Ohio
Date Posted: November-05-2006 at 1:39pm
TRB- have you tried sucking it out with a shop-vac? I know it helped get the straw I dropped down one of my cylinders last week.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1602&yrstart=1991&yrend=1995" rel="nofollow - 1993 Sport Nautique
Posted By: eric lavine
Date Posted: November-05-2006 at 7:25pm
TR, I'll check tommorow and see if the dipstick hole goes into the bottem near the magnet, It may be baffled in that area from splash and it may not harm anything, PCM 1.23? I think were going to have start a new forum and call it the dropsies
Date Posted: November-06-2006 at 8:17am
Thanks Eric- I appreciate it. Yes, its a PCM 1.23.
It didnt go straight in and down the smaller dipstick hole like it should have- it went into the D-shaped hole on the right (towards the stern) if it makes a difference.
Date Posted: November-06-2006 at 8:51am
TR,
if you did go straight down into that little hole you would be safe, if you went off to the side of the hole either way it would near the parts that are turning, but the parts that turn are pretty much enclosed and may be pretty tough to get caught up, its in there now and not to much you can do without dis-a$$embly.
thats something that will bother you every time you run the boat. if you attempt removing I'll walk you thru-it. or pay the shipping and i'll take care of it for you
Date Posted: November-06-2006 at 9:10am
Hmmm, thats what I was afraid of. I think I will wait until spring to fix this- but Ill definitely be asking for your input!
Ive never pulled the tranny before- I a$$ume its not a huge deal? Ill have to do a search and see if someone has written up a procedure.
Date Posted: November-06-2006 at 9:32am
procedure.... support and unbolt
call me ill walk you thru it
Posted By: M3Fan
Date Posted: November-06-2006 at 9:57am
Tim, the easiest way is to support the rear of the engine with a bottle jack under the exhaust manifolds. When I did it on that boat I had a bottle jack under one manifold (the Toyota jack is actually ideal for this) and a shimmed vertical 4X4 under the other side. The engine mounts are near the center of the engine so you're not supporting too much weight- just keeping it balanced really. Take off the Invertaflo muffler and the water hoses to the trans cooler and shift linkage. Throw a towel over the prop and undo the coupling- slide the shaft carefully back. 4 large bolts hold the trans to the bellhousing. Undo those and the rear mounts and you're good to go. I probably have pics of the whole thing actually. I have to do do it for my front trans seal so I'll be doing it this spring again.
Date Posted: November-06-2006 at 10:21am
M3- I just realized that youve done it once to do the damper plate. Glad to hear its not too tricky- I may pick your brain again when it comes time.
Eric, I a$$ume its not too bad to get into the trans once its out? Im not having any problems with it, but is there anything I should replace while I have it out?
Date Posted: November-06-2006 at 12:32pm
when you get it apart you can put everything on a bench and walk you thru it, plates, hubs etc......
Date Posted: November-09-2006 at 10:23am
Eric, I a$$ume its a good idea to do the front trans seal while Ive got the tranny out? Im putting in an order at SkiDIM- is there anything else I should pick up?
Date Posted: November-09-2006 at 12:26pm
I just wanted to add that I just called and spoke to Eric at his shop- very nice guy. What a great a$$et to this board- thanks Eric!
Posted By: M3Fan
Date Posted: November-10-2006 at 11:53am
TRBenj wrote:
I just wanted to add that I just called and spoke to Eric at his shop- very nice guy. What a great a$$et to this board- thanks Eric! |
Good- I'm glad I didn't jump on the anti-eric/advertising bandwagon when he first got here
Posted By: 79nautique
Date Posted: November-10-2006 at 12:43pm
It' really wasn't an anti eric gig it was a self promotion of the buisness, but we're way past that now and hopefully he with the help of the AG can turn the tide and stick it in this guy's a$$ where it belongs but thats on another post.
So tim did you get that thing taken apart and get the tube out?
alittle advice for the future if your doing something and it's going in easy then starts to tighten up don't force it something is wrong that's why it gets harder to do. But I'm sure your well aware of that now.
Date Posted: November-10-2006 at 1:09pm
alittle advice for the future if your doing something and it's going in easy then starts to tighten up don't force it something is wrong that's why it gets harder to do. But I'm sure your well aware of that now. |
No, not yet. Ive got a full seal/gasket kit on order and will tackle this in the spring- for now the boat is put away for the winter. With 1200 hrs, Ill give the internals a good once over and consult Eric on any hard parts that should be changed out.
The hose actually went in the wrong hole pretty easy- I didnt notice something was wrong until I wasnt sucking fluid. It just got snagged on the way out. Either way, lesson learned!
Posted By: Hollywood
Date Posted: November-10-2006 at 1:41pm
79nautique wrote:
alittle advice for the future if your doing something and it's going in easy then starts to tighten up don't force it something is wrong that's why it gets harder to do. |
That's what my girlfriend said last night. Luckily enough I was able to convince her she was wrong though.
Posted By: quinner
Date Posted: November-10-2006 at 1:46pm
That's funny Hollywood, she said the same thing to me the night before last, so I just flipped her over!
Posted By: PLBC
Date Posted: November-10-2006 at 2:02pm
quinner wrote:
That's funny Hollywood, you said the same thing to me the night before last, so I just flipped you over!
Gross. What you do on your own time should be kept off these boards, I am appalled
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5164&sort=&pagenum=1" rel="nofollow - 99
Date Posted: November-10-2006 at 2:03pm
hell Last week when I was over there I tried greasing willy and everthing, even letting get half limp and still couldn't get it in.
Posted By: M3Fan
Date Posted: November-10-2006 at 2:50pm
Hollywood wrote:
That's what my girlfriend said last night. Luckily enough I was able to convince her she was wrong though. |
OK HW, you do win the prize for innovation this time. CQ plays second fiddle in this thread. Good stuff people.
Posted By: quinner
Date Posted: November-10-2006 at 3:06pm
TRBenj wrote:
The hose actually went in the wrong hole pretty easy |
What the ....? Perhaps a new signature for Hollywood?
Posted By: M3Fan
Date Posted: November-10-2006 at 3:13pm
quinner wrote:
What the ....? Perhaps a new signature for Hollywood? |
Wow, screaming LOL at work at that one. I'm going to have to fire myself pretty soon.
Date Posted: November-11-2006 at 8:04am
Tim, maybe if you fill that trans to the top maybe the plastic will float, just a thought
