tom_d_77sn wrote:
Should I punt and take it to a shop?
You'll find all the info you need here on CCF so I think you should line up in punt formation, fake the punt and run for a first down
But since you really like the boat, be nice to it and spend the money on a new double taper shaft, a new strut and a new prop
The ARE shaft from Elbert's is one example of a double taper shaft. The original shaft in your boat is 50 inches long and you'd give the info to Elbert's or whoever you might order it through.
It makes life a whole lot easier removing the old shaft and installing the new one. And...... any future shaft removal is a whole lot easier.
The old shaft has an interference fit between the coupler and the shaft and has to be pressed off and if it was straight when you checked it, you'd then get to experience the joy of installing the coupling with an interference fit onto the shaft. That involves a really hot coupling and sliding it onto the shaft in the bilge, hoping you get it right the first time, otherwise you get to press it off again and start over.
That process isn't really any fun at all
So.....you get a double tapered shaft that comes with a matching coupler for the transmission end of the shaft, cut the old shaft right behind the coupler and pull it out from under the boat.
Then you take your strut and replace it with the SA154 that you mentioned (or go through a lot of aggravation, time and money trying to get it straightened by yourself or a prop shop) Sometimes they can be straightened, sometimes they can't
Then since you have a new shaft and strut, get yourself a new prop. An Acme 540 is a good match for your 77 SN. The old one can be repaired but you'll like the new one from Acme. You can also get a Powertech E40 prop that's basically a copy of the 540 for a fair amount less.
I don't know what you bought a LH prop for in the past, but the one in your picture is a RH prop just like your boat came with from the factory.
The new parts cost you some bucks but you're not paying anybody any labor and having your boat stuck in "boat jail at a shop waiting on someone else to get parts and do it whenever they can get to it.
Prop...........shop around, you'll find a wide range of prices
Shaft .....Elbert's or Discount Inboard Marine. They get them drop shipped from Elbert's.
Strut.....nautiqueparts.com says they have them and use their discount code to get 10% off. The code is PND
Get it all back together and you'll have to do an alignment. Plenty of info on that here on CCF.
Here's a link to a thread on coupler removal that will probably help convince you to get the double tapered shaft
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25700&PN=1&title=coupler-removal-and-install" rel="nofollow - link
Usually the transmission survives this type of issue with no problems.
PS........I'm not crazy over spending money for new parts when MAYBE the old stuff can be salvaged but in this case it's what I'd do.
Here's your picture rotated so it's easier to see the bend in the strut
https://ibb.co/gFm01dw" rel="nofollow">
