Trouble finding Neutral
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=51646
Printed Date: September-16-2024 at 3:09pm
Topic: Trouble finding Neutral
Posted By: cjdet
Subject: Trouble finding Neutral
Date Posted: June-26-2024 at 9:35am
1991 ski Nautique. The neutral lock on my throttle arm is worn and having a tough time locking in place this seems to be causing the boat to not want to start. I when move the throttle back and forth i can eventually get the trans to find neutral and turn over and start. Will a new throttle assembly solve this issue or do i have another issue at the transmission?
Posted By: MourningWood
Date Posted: June-26-2024 at 10:40am
My first thought is a worn/failing throttle cable...
------------- 1964 Dunphy X-55 "One 'N Dun"
Posted By: MrMcD
Date Posted: June-26-2024 at 12:28pm
I think I wouild remove the cable at the transmission. Make sure the tranny is in neutral and see if your starting issue is the same or fixed. There is a neutral safety switch in the tranny that could also be failing. Easy to rule out.
