Gentlemen, I know this is not a boat motor but I was hoping to get some ideas from all the gracious motor experts on here. My friend has a Ford 289 in his Bronco, newly rebuilt with 3,000 miles, stock heads, stock valves, stock valve springs, an RV cam, Edelbrock performer intake manifold, stock rocker arms, 650CFM Edelbrok carburetor, newer style billet distributor in very good shape.
The engine seems to be missing and also making a noise, a little bit metallic sounding and kind of a tapping sound. The sound happens at the same time the engine seems to miss and stumble. When it misses I can see the engine shake a little bit. Noise frequency increases with RPM.
I saw it in person for the first time yesterday and we did the following to troubleshoot it:
-Tightened loose header bolts. -Pulled, checked and gapped all the plugs. -Made sure none of the spark plug wires were shorting/grounding to the engine. -Pulled the distributor cap to inspect cap and rotor and all looked good. -Used a mechanic's stethascope to try and listen for a loud rocker arm or possbily a bad crank or rod bearing, I couldn't determine where the noise was coming from. If anywhere I would have to say passenger side valve cover. -Pulled passenger side valve cover, rotated motor over and checked each rocker arm one at a time for something loose but didn't find anything loose. -While engine was running I pulled one plug wire at a time on the passenger side to see if that made any difference to how the motor ran to try and isolate it to a single cylinder but was generally unsuccesful.
I am wondering if it could be a collapsed or failing lifter? If it was how would I verify that? Any other ideas of what it could be or how to troubleshoot it?
------------- 1980 SN Project
