Recirculating Pump
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5282
Printed Date: February-21-2025 at 9:05am
Topic: Recirculating Pump
Posted By: Mark Mel
Subject: Recirculating Pump
Date Posted: November-29-2006 at 2:38pm
When looking over my engine (351w) during winterizing, I noticed the pulley on the recirc pump(I a$$ume it was the recirc pump, it's the middle pulley) had some side to side play in it. Felt like the shaft not the pulley itself.
Is this something I should be worried about? I have no leaks from that area.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=972&sort=&pagenum=4&yrstart=1976&yrend=1980" rel="nofollow - 1978 Nautique
FBook - www.facebook.com/charliedontsurfct
Posted By: Mark Mel
Date Posted: December-01-2006 at 9:49am
Anyone?
Posted By: 81nautique
Date Posted: December-01-2006 at 9:57am
Mark,
Last run out this fall I noticed the infamous Ford Water pump rattle. I found a little side play but no water leaking yet. I think it's a matter of time so I'm going to replace it before hitting the water in spring.
------------- You can’t change the wind but you can adjust your sails
Posted By: Mark Mel
Date Posted: December-01-2006 at 11:44am
Thanks Alan. I'll prob look at replacing it also.
Posted By: boat dr
Date Posted: December-03-2006 at 10:01am
Mark Mel,be careful when you buy a new pump,the catalogs will show two types of ciculating pumps,one will say bi-directional,the other says CCW, and a large price difference.The true CCW is what you need,and install new belt with just enough tension that the belt dont squeel,too much tension will kill the waterpunp bearing in short order.............boat dr
------------- boat dr
Posted By: eric lavine
Date Posted: December-03-2006 at 10:33am
Boat doc, figured out problem, when they welded the case the heat caused the inner race to move forward in the bore. knocked it back down and it was good to go
eric
Date Posted: December-03-2006 at 11:08am
Mark,
If I remember right you got your 540 from Skidim, Vince will have the pump you need too.
Posted By: SS-201
Date Posted: December-06-2006 at 6:01am
They make a newer pump for Ford RH engines, Ski-dim sells them.
------------- SS 201
