Rudder adjustment/Free play
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=534
Printed Date: January-30-2025 at 11:35am
Topic: Rudder adjustment/Free play
Posted By: Jamie
Subject: Rudder adjustment/Free play
Date Posted: June-18-2004 at 1:06pm
I need to adjust the rudder in order to get the free play out on my 1968 Ski Nautique- anyone have any tips on how to attempt this successfuly?? Thanks
1968 SN 1548
Posted By: Rick
Date Posted: June-20-2004 at 5:40pm
It depends on what is causing it. If the bolt to the tiller from the cable is loose replace the bolt. Put washers on both sides of the cable grease the one between the cable and tiller and use a nylock nut. Tighten it until it is snug but still moves. If it is caused by play in the pivot plate replace the plate and make sure the mounting bolt is tight.( This is the reason for the recall ongoing now with the 2003s.)
http://www.correctcraftfan.com/diaries/details.asp?ID=250&yrstart=1996&yrend=2000%20" rel="nofollow - 2000 Ski
