Engine loosing power
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5486
Printed Date: November-27-2024 at 4:35pm
Topic: Engine loosing power
Posted By: subli572
Subject: Engine loosing power
Date Posted: January-09-2007 at 4:36pm
Hi, happy 2007 for everyone. I have a '89 Ski Nautique, the engine has arround 1,150 hours and recently I'd noticed that the engine is loosing power, especially when we do the slalom course I can feel how the boat breaks when the skier pulls. What do you suggest me? rebuild the engine?
Thanks for any advice,
Posted By: todicus
Date Posted: January-09-2007 at 6:22pm
Can you clarify your statement ?? There are lots of things you can check, but don't quite know what you mean yet.
Living outside the wake
http://www.correctcraftfan.com/diaries/details.asp?ID=1525 - 95GT-40SNOB
Posted By: boat dr
Date Posted: January-10-2007 at 8:44am
Sub, a motor that has that kinda hours on the clock will slowly lose power ,and not always because of internal wear,rings, valves, but because the timing chain streches. this not only retards timging but also retards your valve timing as well. Easy test, pull dist. cap,turn your engine over, plugs out,with a breaker bar. when you have taken up the slack, the rotor will move,now reverse rotation, the rotor should move at the same as the crank . the "lagtime" tell you how much slack or stretch is in your chain and gears............ boat dr
boat dr
Posted By: subli572
Date Posted: January-11-2007 at 4:02pm
Thank you for your answers.
Todicus, what I mean is that when the skier is pulling, tha boat lose power reducing the speed on every pull, its very hard to maintain the speed of the boat while the skier is on the course.
boat dr, I'll try what you're telling me, is there any gaskets or something I have to change for better performance?
Posted By: 79nautique
Date Posted: January-11-2007 at 4:05pm
the gaskets are not going to help performance wise. To fix the problem if it is a stregthed timing chain is to replace the timing chain then that will correct the valve timing relative to the piston movement.
Posted By: boat dr
Date Posted: January-14-2007 at 5:59pm
79,i know i'm from the south and we speak a little different than you and sometimes we have our own name for certain parts,But what the hell is this???????????????
        '"a stregthed timing chain "
boat dr
Posted By: Hollywood
Date Posted: January-15-2007 at 10:12am
'doc
stretched + lengthened = stregthed
Posted By: GottaSki
Date Posted: January-15-2007 at 11:35am
Maybe his skier is getting better.
River Rat to Mole
Date Posted: January-15-2007 at 12:52pm
where's spell check, kevin got.. what's the problem doc... got to spell everything out correctly\\\\\\\//
